Posts: 9,602 |
You went through 3 SVT engines (plus your original I suppose)
Either you should be sueing all the incompetant mechanics that did the work for you or never touching a car again.
Something is definitely amiss here!
BTW a swap from Duratec to Zetec is ludicrous. If you want one that badly just buy a car with a Zetec & MTX in it.
Personally I suggest picking a different car altogether. You seem to have no luck with these cars.
'nuff said
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 10,015 |
Originally posted by DemonSVT: You went through 3 SVT engines (plus your original I suppose)
BTW a swap from Duratec to Zetec is ludicrous. If you want one that badly just buy a car with a Zetec & MTX in it. Personally I suggest picking a different car altogether. You seem to have no luck with these cars.
'nuff said
Yeah what he said! How the fugg do you blow 3 SVT engines? Do you drive in tight right hand circles all day long with 1 qt of oil in the engine?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21 |
Well I guess I should clear things up. I bought the car with a regular duratech that had a bad rod knock(spun bearing I am told), I put in a rebuilt SVT engine that was rebuilt incorrectly(thank you Canton auto) and this one that I know I drove hard, but I kept a full crankcase of Mobil 1 and changed it every 2,500. I have had freinds that have had problems with their duratechs also. I have gotten very efficent at taking the engine and trans out of contours, so swapping a turbo zetec to it should be no problem. Parts are way too expensive for the duratech. Just the gaskets for my rebuilds were $400.00, and that was with my employee discount. I know I run them hard, but in no means to I abuse them. As far as buying a whole other car, I really like mine. I have all options, rear disc, SVT body. Why start all over with a gl? I have all winter to do the swap.
97 champaign contour SE
3rd SVT engine(DEAD)
SVT bodykit
18 Team Loco 150's
215/35ZR/18 Nitto
DVD, Playstation 2
15 Audiobahn
DEI amps
Mystic Interior accents
Ram air
Carbon fiber JSP spoiler
Tribal Graphics
Indiglo SVT guages
Posts: 10,015 |
Well, best of luck, but be warned that you'll need a whole new PCM, trans and engine as well as who knows what to do the transformation.
AUSSIE ENDLINKS $70
Posts: 976 |
Why not use clevite 77 rod bearings and federal mogual mains or the clevite 77 mains when they come out?? Then your covered, they will last well beyond the stock lead(i think) bearings. Throw a DMD on there and if you spin another one I would be amazed. Sounds like very few of those engine built were the duratec's fault, ie bad motor rebuilds, etc. Tri-metal bearings and a DMD will damn near cure the spun bearing problems.
Posts: 21 |
I was already thinking I was going to need all that. Unfortunatly I have done the engine replacement in a contour 3 times now so it is not even a hassle ![](/ubbthreads/images/icons/rolleyes.gif) God I hope this is the last time.
SVT bodykit
18 Team Loco 150's
215/35ZR/18 Nitto
DVD, Playstation 2
15 Audiobahn
DEI amps
Ram air
Tribal Graphics
Indiglo SVT guages
Posts: 2,387 |
I know it's been asked already, but you havent responded to what seems to be the most obvious explanation regarding you're troubles, from everything that i have read, 99.9% of blown v6's result from spund bearings = DMD, oil starvation = baffled oil pan, and overheating = waterpump. Maybe your biggest problem is overlooking small solutions that can solve big problems.
98 3.0 svt: Sold
Posts: 9,602 |
You will need a new subframe, all the harnesses, sensors, TB, etc... The list covers nearly everything under the hood and electronics. By the time you collect all the parts you need you will have bought an entire donor car. A complete waste of time & money. Though I have seen pics of your car so I guess you are used to that. (what's with the aluminum park bench?) 4 blown Duratecs ![](/ubbthreads/images/icons/nonono.gif) - Ride a Bike! You don't deserve a car IMO & from your track record!
2000 SVT #674
Posts: 21 |
There is no need to be a dick! I am very happy with my car and that is all that matters. I have read your posts, and you do nothing but bitch. If you have nothing constructive to say. Your car is yours and that makes you happy. Who am I to say it is a waste of money. Think about it jackass!
SVT bodykit
18 Team Loco 150's
215/35ZR/18 Nitto
DVD, Playstation 2
15 Audiobahn
DEI amps
Ram air
Tribal Graphics
Indiglo SVT guages
Posts: 21 |
As far as to the other ?'s, I do not have a DMD, the water pump is still good, and I ran an extra 1/2 quart of oil. Either way I need a new engine, so I think I will spend the same amount on a zetec build-up.
SVT bodykit
18 Team Loco 150's
215/35ZR/18 Nitto
DVD, Playstation 2
15 Audiobahn
DEI amps
Ram air
Tribal Graphics
Indiglo SVT guages
