according to terry there is 2 kits available from demon dynamics but according to DD website, there is 3. i believe the stage 3 was something around $3800. not to bad i think. a list of parts include:
T3 Turbo complete with standard 31 actuator
Set low compression forged Pistons to achieve 7.45:I ratio
Head gasket Multi-layer steel
1 set of grey Injectors
Modified fuel rail
Demon Dynamics uprated fuel pump
Fuel pressure regulator
Demon Dynamics inlet manifold
Inlet manifold adaptor plate
Demon Dynamics Turbo exhaust manifold
Exhaust down pipe adaptor plate
Lambda sensor adaptor for exhaust down pipe
De-compression gasket
1 set uprated con-rod bolts
1 set of head bolts
Breather one-way valve
Boost silicon Hose set
1 set of spark plugs
Breather blanking plate
Turbo oil feed adaptor ref engine block
BSP oil feed adaptor
BSP adaptor for Turbo oil return ref sump
Turbo rated braided oil feed pipe
Fuel Hose
Jubilee clips
Polished stainless steel pipework
Cylinder heads will require machining for use of the correct spark plugs
heres the website if u wanna check it out
http://www.demondynamics.co.uk/kit2.htm
