Page 3 of 4 1 2 3 4
#490636 12/02/02 05:57 AM
Originally posted by johnny hennessy:
so I should stick with the OBD II so I don't have to mess with the computer?
yes
2003 Subaru WRX some mods Even if you don't have the answer, you certainly have to admire the problem. aka ZetecRacing
#490637 12/02/02 06:32 PM
does the focus engine have the same computer?
thanks for helping me out with this
Built April 18th 1998 #5770 of 6535 Reborn: July 11, 2004 3L and gone again 12/13/2005 new ride: 98 Silver frost SVT with all my old goodies!!!!
#490638 12/02/02 06:34 PM
CEG road warrior
CEG road warrior
Yep.
#490639 12/02/02 06:36 PM
i guess I found my choice
#490640 12/02/02 08:52 PM
Can someone tell my why you have to use a 95 engine with a 95 computer? I think the 95 can be made to use all the sensors etc that the 96 has. Am I wrong about this?
Lee Cox No Contours to speak of...
#490641 12/02/02 10:25 PM
I have a Zetec from a 96 contour in my 95 mystique. It was put in before I got it. I don't know how much under the hood is 95, and how much is 96.
I do know that my CEL stays on, all the time. The engine runs great, and there are no codes stored in the computer (Ford and Autozone both checked). I don't know if this has anything to do with the 95-96 hybrid or not. The only thing I found that was clearly not compatible was one sensor mounted on the firewall. I don't even remember what it is. Has a couple of vacuum lines and electrical lines going to it. I think it goes to the EGR. I had to modify the connector to make the wires fit. I also had to change the vss to hook up with the speedometer cable. Other than that, I've not noticed any differences.
#490642 12/03/02 12:58 AM
what's wrong with using a contour zetec?
#490643 12/03/02 04:05 AM
Yep.
to be more correct....
yes I just said "more correct"
yes and no.... does each contour within the same years use the same computer???? answer not really... hence the code differences... so as I said before does the focus use the same computer as a pre 98 yea and no...
#490644 12/03/02 06:03 AM
Nothing I thought that the zetec from a focus would allow me to use more aftermarket things, without major mods. If I can find a tour Zetec than I would use that. Unfortunately, I haven't found any Zetecs at the junkyards that are in semi-decent shape
#490645 12/03/02 06:14 AM
CEG road warrior
CEG road warrior
Yep.
Jeez nothing a little reflash couldn't fix.
Page 3 of 4 1 2 3 4
Moderated by  Loco4G63
