Posts: 3,465 |
Originally posted by johnny hennessy: so I should stick with the OBD II so I don't have to mess with the computer?
yes
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 1,051 |
does the focus engine have the same computer? thanks for helping me out with this
Built April 18th 1998 #5770 of 6535
Reborn: July 11, 2004 3L and gone again 12/13/2005
new ride: 98 Silver frost SVT with all my old goodies!!!!
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by johnny hennessy: does the focus engine have the same computer? thanks for helping me out with this
Yep.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,051 |
i guess I found my choice
Posts: 430 |
Can someone tell my why you have to use a 95 engine with a 95 computer? I think the 95 can be made to use all the sensors etc that the 96 has. Am I wrong about this?
Lee Cox
No Contours to speak of...
Posts: 1,459 |
I have a Zetec from a 96 contour in my 95 mystique. It was put in before I got it. I don't know how much under the hood is 95, and how much is 96. I do know that my CEL stays on, all the time. The engine runs great, and there are no codes stored in the computer (Ford and Autozone both checked). I don't know if this has anything to do with the 95-96 hybrid or not. The only thing I found that was clearly not compatible was one sensor mounted on the firewall. I don't even remember what it is. Has a couple of vacuum lines and electrical lines going to it. I think it goes to the EGR. I had to modify the connector to make the wires fit. I also had to change the vss to hook up with the speedometer cable. Other than that, I've not noticed any differences.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 21,653 |
Originally posted by johnny hennessy: i guess I found my choice
what's wrong with using a contour zetec?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,465 |
Originally posted by Hector: Originally posted by johnny hennessy: does the focus engine have the same computer? thanks for helping me out with this
Yep.
to be more correct.... yes I just said "more correct" yes and no.... does each contour within the same years use the same computer???? answer not really... hence the code differences...  so as I said before does the focus use the same computer as a pre 98 yea and no...
aka ZetecRacing
Posts: 1,051 |
Nothing I thought that the zetec from a focus would allow me to use more aftermarket things, without major mods. If I can find a tour Zetec than I would use that. Unfortunately, I haven't found any Zetecs at the junkyards that are in semi-decent shape
CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
160HP/141TQ
