Posts: 3,335 |
In reply to:
Zetec S - This is the baby Zetec as fitted to the late Fiesta, Puma and 1.4/1.6 Focus models. It has been produced in 1.25, 1.4, 1.6 and 1.7 litre capacities. These engines bare no mechanical resemblance to the Zetec E.
Right out of Butron Power's catalog, page 9. Going smaller would let the engine rev higher, but the lower power output would be a bad thing. Also, it would cost just as much to ship that engine from the UK as it would the Cosworth.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 3,465 |
no it wouldn't be faster...
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 21,653 |
i didn't mean zetec s,, skool has my mind all messed up... i mean the engines they build up, they come in any zetec size, though my be carburettated(sp?).
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,051 |
I thought that the cosworth engine was able to give more output then our zetecs? must have misread. guess I will go with the focus block or the original tour'
Built April 18th 1998 #5770 of 6535
Reborn: July 11, 2004 3L and gone again 12/13/2005
new ride: 98 Silver frost SVT with all my old goodies!!!!
Posts: 21,653 |
Originally posted by johnny hennessy: I thought that the cosworth engine was able to give more output then our zetecs? must have misread. guess I will go with the focus block or the original tour'
umm i believe the cosworth engine does have more output,,, we were discussing zetec s (name of smaller zetec) we have zetec e (1.8/2.0)
98.5 SVT
Posts: 1,051 |
oh, sorry about that I was just seeing which is the best way to go and got lost with all the different names
Posts: 368 |
get a 95 Zetec, and rebuild it with better internals. Rebuild the tranny as well, then you can put your clock back down to ZERO!!
The reason i would go with the 95 zetec, is because it is truely the easiest North American zetec to mod and build up. It doesnt have VCT, it has the OBD I, EEC IV, so its more user friendly, computer wise. Also the 95s were built just a tad bit better/stronger, due to the first year release (or so I am told, and so I have experienced, as i have a 95).
But, if you have a 2000, maybe 99 year tour, it may work better for you, if you use a 96/97 yr Zetec, which is made for the OBD II/ EEC V. Also, since it basically uses the same computer as the focus, you can just about use all of their gear, like the 70mm MAF, which only difference is that the tour has a post type sensor, and the focus has a two wire strip down the center. However, a few minor adjustment made with your handy-dandy tool box and power tools, and you have yourself a 70mm MAF. Then you could probably also bolt on the FSVT IM. I am goin to look that one up, cause i also want to put it on my tour and my focus.
But, the possibilities are endless...
2002 Focus ZX3, MTX-75: A good amount of mods
2003 SVT Focus ZX5, Getrag-6: FS Stressbar
Best mod ever to my tour: A Beautiful passenger seat filler, that is my girl!!
Posts: 1,051 |
so my having a 96 tour it would be best to get the 95 engine? wouldn't i have to change the codes or computer parts as well? thank you for all your help
Posts: 3,465 |
no the 96 is OBD II if you want a 95 you would have to change the computer.
aka ZetecRacing
Posts: 1,051 |
so I should stick with the OBD II so I don't have to mess with the computer? sorry, I am still new to the whole fixing up car thing
