Page 4 of 23 1 2 3 4 5 6 22 23
9
20% on alternator
3.0 14.392@97.237 2.302 60ft OEM 4-bolt LCA's $105 each Watch me go
My question is does this sacrific engine life? Cuz I've heard the U/D pulleys are a bad idea...I have a DMD! I car about performance that doesn't hurt my girl!
Originally posted by 96BlackSE:
Yup you can still your DMD
Uhmmmm....
yeah...these are for the alternator and the power steering pump. shouldn't affect engine life. somebody please correct me if I am wrong.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
9
Uhmmmm....
This is not a crank pulley
Its a p/s and alternator pulley which has nothing to do with your crank pulley
9
Its doesn't sacrifice engine life
It actually longens your alternator and p/s life
Here you can read up on it
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=perf&Number=75483&page=1&view=collapsed&sb=5&o=14&fpart=1
Well if it "longens" accesory life, I guess I would be in...
I am worried about the 20% underdrive on the alt, for the stereo wielding people...anyone know how many amps are produced by the alt at idle? I'd like to see what 20% less would be, and check for amperage requirements (can anyone say rear defroster?)
A very cool idea though, I have been wanting these for a while...
Marco Tatta 98.5 SE MTX, Duratec EGR block, indiglo gauges, custom shift boot, monsterflow intake, Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race s carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Originally posted by mangler:
1. I am worried about the 20% underdrive on the alt, for the stereo wielding people...
2. anyone know how many amps are produced by the alt at idle? I'd like to see what 20% less would be, and check for amperage requirements (can anyone say rear defroster?)
1. Yes at idle with your noise pollution thumping it may pose a problem.
However with all the extra weight of the equipment & subsequent tremendous strain on the electrical system maybe you shouldn't be worried about underdriving your alternator for performance or alternator longevity in the first place.
I would not recommend one to anyone with a large stereo setup. For that matter I would also recommend you upgrade a few or your current components as well (battery, alternator, extra capacitors, etc) You know; the normal stuff needed on any vehicle pushing any serious wattage. Not doing so is just inviting component failure.
2. It doesn't work that way. 20% slower revolutions does not equate to 20% less amperage output.
The stock alternator puts out 50-70amps at idle. (load dependant of course) At ~2000 rpm it can exceed 100amps.
It's rated at 140amps, but definitely can exceed that under heavy load and enough rpm to sustain it. (10-20% safety factor) Regularly exceeding it's "rated" amperage with shorten it's life. (why large stereos eat alternators & batteries)
With this pulley the only time you may notice a draw on your electrical system is at idle with everything running. The battery plays a large factor in this as well since it is used as a backup supply when the demand exceeds the alternator's output.
Personally I never saw a problem with a ~13% UD alternator pulley and the stock battery. With the dyna-batt (40% the reserve time) I have seen the headlights dim. However only when the idle drops below 700rpm (basically when coming to a stop with the clutch in) & I have everything (head & driving lights, radio, blower, brake lights, etc) running. With the driving lights & blower off it never does it. Above 700rpm (or at idle) it never does it regardless.
I'm in for a P/S pulley for sure.
BTW, check your PM's Nima, it is regarding a PM you had sent to me earlier!
Thanks,
Cool Toe Chris
Cool Toe Chris
Any updates? I'm itchin' to mod!
Chris NJ 98.5 SVT Silver Frost
Moderated by  1314_dup1
