#490324 11/28/02 05:05 PM
My SVT Offline OP
Hey needing some help. My fan for the heater and ac only works for low and high there is nothing esle no more it is ether low or high. Just lokking for help to solve my problem. THANKS ALOT
#490325 11/28/02 05:07 PM
It might be the switch. Usually when the resistor goes out it only works on high. Try to find a used switch from the junkyard. If that doesnt fix it I believe the resistor costs like $10.00 from Ford and is located under your glove box.
www.ChicagoCEG.com 2006 White Grand Prix
#490326 11/29/02 04:50 AM
Take it to the dealer first, if it's the resistor, that's a recall and it's free. With mine, it only came on low. I had to push the knob in and hold it for high to work. Took it to the dealer and sure enough, it was the recall. First time I've been in a dealer and walked out with the same amount of money that I walked in with
#490327 11/30/02 01:06 PM
H
H
Depending on year of car there are recalls/extended warranty on blower switch and blower motor resistors. Best to check your VIN at a dealer to see if they apply to your car.
