#48815 11/30/01 02:07 PM
I did a search, and really didn't find what I was looking for. I was driving last night, and all the sudden the heat went way up. I thought it might be instrumentation, but then the check engine light went on. I pulled off and it was steaming in there. It was also not blowing hot air inside the car. The mechanic came and did a quick check and said he didn't think it was a head gasket, but a clog somewhere in the system. I looked and I wasn't leaking anywhere in the ground. Any ideas? Someone told me to take it to a lube place at the ford dealer to do a flush and fill and pressure check to see if anything is internally messed up. Would that help? Also, how far do you think it is safe to drive it at low speeds to get it to a ford dealer?
95SE ATX Champagne
Mods:
Levoc Chrome ATX shifter
JPett's custom leather ATX shift boot
#48816 11/30/01 02:14 PM
Water pump.
#48817 11/30/01 02:21 PM
Second water pump. Dont drive it or you WILL have a dead head gasket (if you havn't already)
Mad Mole
Visit Mad Moles Mondeo Madness
2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc.
192 BHP, Faster than a speeding Duratec!
#48818 12/01/01 06:41 AM
How many miles on your car? Does Contour wp really has more fails than other cars?
QUOTE]Originally posted by drewdogg00:
I did a search, and really didn't find what I was looking for. I was driving last night, and all the sudden the heat went way up. I thought it might be instrumentation, but then the check engine light went on. I pulled off and it was steaming in there. It was also not blowing hot air inside the car. The mechanic came and did a quick check and said he didn't think it was a head gasket, but a clog somewhere in the system. I looked and I wasn't leaking anywhere in the ground. Any ideas? Someone told me to take it to a lube place at the ford dealer to do a flush and fill and pressure check to see if anything is internally messed up. Would that help? Also, how far do you think it is safe to drive it at low speeds to get it to a ford dealer?[/QUOTE]
#48819 12/01/01 06:08 PM
95SE ATX Champagne(the original svt)
Whatever... ATX to boot :rolleyes:
2000 SVT #674 - Check it out!
#48820 12/12/01 09:56 AM
W
W
I had a problem like that with my contour, did the flush, water pump new, hoses and still overheated but did not spit anything out. My problem was the low speed fan locked up on my 95 contour gl and caused havoc till the high speed fan came on to try to keep things cool. Ford eventually put a recall out for fixing the part and putting in a fuse to keep it from frying the wire harness when the low speed fan would lock up. Just get into the engine bay and see if the fan spins freely, if so check to see if it comes on with the car running.
#48821 12/12/01 10:12 AM
I HAVE A HEATING PROBLEM. MY FAN FUSE BREAKS ALL THE TIME CAUSING NO FAN TO TURN ON AND IT TO OVER HEAT.
98csvt(red)white 19''Axis se7ens on toyo 225/35/19's injen intake,cust exhaust, High Rev's racing clutch,and flywheel .whatever its takes to run 12's (system)Eclipse 5442,Boston 6 1/2" pros, Eclipse 5x7 point scourse,PPIpc4400,PPIpc2600(chrome),power cap,2 12"JLW6
YOU WILL RESPECT THE FAMILY CAR
#48822 12/12/01 04:04 PM
sounds like your fan bearings are shot. I believe it is covered under recall.
Bt
