Posts: 57 |
Did anyone ever dyno over 300 Wheel hp with this turbo kit? If not whats the most hp dynoed so far with this kit?
Posts: 7,025 |
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,786 |
Once the kit gets put back on Keyser's car, it should be easily more than 300HP. That 292 was run at 100F degrees of ambient air temp inside the shop. (Phoenix, AZ!)
Cool, moist air should make things even more interesting.
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 670 |
Is that going to be the stock psi setting or higher and thus no warranty. 300fwhp at stock setting would really be nice
-R-
I'm a Karate Man. Karate men..bruise on the inside.
"The difference between oversteer and understeer: oversteer is when the passengers are scared, understeer is when the driver is scared." -Driver Unknown
Posts: 2,676 |
there's no warranty regardless, it's a turbo kit, the high under hood temps, excessive wear, etc. all void any ford warranty and I've YET to hear of a company that warrants a kit for turbo's. . .but, it's all in the name of fwhp!!! I'd totally slap one on a low compression 3L swap, if I had another car to drive (because problems would persist) and if I had the money.
Posts: 246 |
Originally posted by ssmumich00: there's no warranty regardless, it's a turbo kit, the high under hood temps, excessive wear, etc. all void any ford warranty and I've YET to hear of a company that warrants a kit for turbo's. . .but, it's all in the name of fwhp!!! I'd totally slap one on a low compression 3L swap, if I had another car to drive (because problems would persist) and if I had the money.
I believe he was referring to the Street Flight warranty.
99 SVT ~ Silver Frost ~ #2621
mods? a few...
Posts: 670 |
Originally posted by skid123: Originally posted by ssmumich00: there's no warranty regardless, it's a turbo kit, the high under hood temps, excessive wear, etc. all void any ford warranty and I've YET to hear of a company that warrants a kit for turbo's. . .but, it's all in the name of fwhp!!! I'd totally slap one on a low compression 3L swap, if I had another car to drive (because problems would persist) and if I had the money.
Exactly.
Posts: 10,015 |
The individual parts in the kit are warrantied fropm what I understand, but the engine (with kit installed)is not. Anyone can throw the kit on, crank the boost to 20psi and annihilate the thing, so you can never ask any company to warranty that.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,860 |
I have the kit back on. I am far from tuned however. Time being an issue late on night we wrote a program that put me at pretty much just so I could drive it. Pulled a lot of spark and added a lot of fuel. 250ish fwhp.
The heavier spring that I put in is 10psi on the nose. It will be one of the options when ordering.
Parts are warrantied by the manufacturer.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 2,676 |
Originally posted by Stazi the Aussie: The individual parts in the kit are warrantied fropm what I understand, but the engine (with kit installed)is not. Anyone can throw the kit on, crank the boost to 20psi and annihilate the thing, so you can never ask any company to warranty that.
that's what I was saying, parts warranted, engine that put on isn't. . .
