Posts: 133 |
The factory cooler is in the radiator, does an OK job of keeping the fluid cool under most conditions. These coolers are added after the factory cooler. The fluid flows through the cooler in the radiator and then is futher cooled by the auxillary cooler.
Towing or lots of stop and go driving will push trans fluid temps up. I have read that contour trans are a little weak in the pump dept, and so can start getting warm on extended high speed runs also, these coolers help this. Your trans will generally last longer the cooler you can keep the fluid.
Posts: 21,653 |
could i add a large tranny cooler (will be removing a/c condesor soon) and use factory tranny cooler (in radiator) to cool oil?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: advantages??? a longer living ATX mainly. the ATX gets very hot in certain conditions, especially if you chose to drive with O/D off. it will help performance slightly as your transmission will have less wear and be more efficient.
Trust me don't mess with the radiator connections. That is how I messed mine up. I'm sure you don't want to spend another $130 for the radiator.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 21,653 |
haha you quoted the wrong thing  .... what kind of damage did u do? how? why? is there any way to do it w/o screwing it up?
98.5 SVT
CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
160HP/141TQ
Posts: 2,469 |
how come the fluid in a mtx doest get as hot? Or does it its just not as bad?
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by dubkatz: how come the fluid in a mtx doest get as hot? Or does it its just not as bad?
All fluids get hot but it is the design of the Ford Contour's ATX which makes the trans fluid getter hotter.
Hector
257HP/259TQ
160HP/141TQ
Posts: 21,653 |
ford really messed up, i have concluded it doesn't have a true filter because ford couldn't figure out how to use one w/o losing pressure.
98.5 SVT
