#487282 11/24/02 03:38 PM
F
F
I have a '95 SE duratech. I want to know how hard it is to swap an SVT engine into it. I am not concerned so much about physically getting the engine in there, but I have a sneaking suspicion that I will have to change virtually every inch of wiring in the car.
Basically, if anyone has done this, please just give me some insight into any unexpected problems.
thanks
-FD
1995 Contour SE V6 5 spd
#487283 11/24/02 03:53 PM
you would be MUCH better off going for a 3L. they are much cheaper, and more powerful.
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#487284 11/24/02 04:10 PM
F
F
Well, I kinda want a whole car because I want to update a number of things above and beyond the engine. I also think it would be better to swap EVERYTHING over to SVT spec because the aftermarket loves those SVTs. Also, it would be much easier to put in a 3L later on once I switch to SVT electronics and there is something with the knock sensors yada yada yada....
Also, the pass key system...? I think thats what its called where the computer recognises the car's key as an anti-theft system. On a later car, I assume I would have to swap over the ignition/wiring/door locks, and whatever else in order to get the car to start up. Is that correct?
-FD
#487285 11/24/02 06:37 PM
If you have all these plans, why not just buy an SVT?
#487286 11/24/02 08:16 PM
F
F
Cause...a wrecked SVT is fairly inexpensive to acquire. Also, my car has new suspension and brakes. In addition, I like having a sleeper. Finally, I just really like my car. I don't want to go through the time, expense, or effort to get rid of a car that I like.
So is anyone gonna help me out instead of trying to talk me out of it??? If I wanted someone to tell me to leave it alone, I would have asked my girlfriend.
-FD
#487287 11/24/02 09:00 PM
9
IIRC, Simon was trying to swap an SVT engine into his 1996 Duratec and it was more trouble than it's worth. I too was looking into doing this, but then I realized how much easier the 3.0L is.
Austin -officially a troll See it here Pro-Flow w/ optimizer STILL for sale
#487288 11/25/02 03:16 AM
Just do the 3L, it's easier because you won't have to pull the engine again when you want 3L. I used the stock EEC-IV wiring harness with very little modifications.
#487289 11/25/02 08:51 AM
F
F
Can you be more specific in terms of what you did for modifications?
-FD
#487290 11/25/02 04:27 PM
If you use the SVT computer you need the harness for the PASS key and all the adl. parts. The pin outs at the computer are differant. I belive it requires much re-wiring.
I agree with above. Put in a 3.0L. Performance parts that work on the SVT work on the 3.0L.
'98.5 SVT E1 T-Red, Midnight Blue All stock
#487291 11/25/02 05:35 PM
Yes a Wrecked SVT is inexspensive to aquire, but the work involved in moving everything over will be very involved You would be better served to just get a 3.0 and the seats if that's what your looking for.
Lee Cox No Contours to speak of...
