Posts: 14 |
FOR A WHILE NOW, AFTER I TAKE MY FOOT OFF THE BRAKE FROM A DEAD STOP, IT MAKES THIS POPPING NOISE! IT'S NOT COMING FROM MY DOOR SPEAKERS, IT'S IS DEFINITLY MECHANICAL. IS THIS NORMAL, HAS ANYONE HEARD OF THIS PROBLEM?
Posts: 1,050 |
I had a very similar problem. Sometimes I would have the break applied and when I would release it the pads would stick. It made a huge Pop or clunk noise when I went to move, like it popped out of gear. Scared the crap out of me. It actually left the outline of the pad on the rotor when I jumped out and check it one day; that day it was very hot out. It was under warranty and the problem went away when the dealer changed the brake pads.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 233 |
Mine does something similar, although it only happens when I have left the car overnight with the emegency brake set.
I release the brake, let out the clutch, and I get a fairly loud pop from the rear brakes.
It tends to be more pronounced if it has been raining overnight or otherwise damp outside.
1998 E1 SVT - Toreador Red Production #4794 of 6535 Build date: 2/25/1998 Mods completed: - Pre '97 sail panels Mods planned: - K & N Air Filter - Side marker lights
Posts: 654 |
I have the exact same problem as you do, SaratogaSVT, on my Non-SVT. have you found the source of the problem? Mine doesnt do it very often, but when it does, boy do I know it cause it is loud! Peace y'all... -Nick
"My family hauler can kick your family hauler's @SS!" ~~~~1999 Contour SE Sport~~~~ -KKM True Rev -Custom cat back Flowmaster exhaust -All Cat's fixed. -SHO Shop Off-Road Y-pipe -Many other Mod's done...
Posts: 79 |
this would not help.... but i felt like i should post it. There's couple of things that i do not touch at my car: brakes and steering. I do change my pads, but that's it. The reason for it is that these two things will keep you safe on the road. This doesn't mean that when i take my car in for service i'm not closely following what they "repair".... I know it's not always a pleasure to have smb around checking and asking all kind of stuff.... but hey ->> it's my life (possible others' as wel) and i don't wanna "take a brake" cause smb fooled with my car... That's me.
Andrei. 98.5 Contour Sport SE,V6,MTX beeeph.
Posts: 97 |
I recommend Bendix pads; low dust, low fade, they don't squeal anywhere near as bad as factory or cheapos, and they don't stick! I've used Bendix on several cars, and the difference is wonderful.
Black/tan early '98 Contour SE Sport; V6, MTX, loaded Kenwood KDC 316S CD deck; aux. dome light mod; trunk popper spring; resonator bypass; hood strut mod; SVT grille; Continental tires Mom also has black/tan '98 Mystique LS; V6, ATX, Alpine CD deck
Posts: 7,329 |
I have had bad results with Bendix pads & I used to like them... Even their new Titanium line. Bad fade!!!, average dust, average wear, but harsh on rotors big time...
I would recommend Ferrodo Selectra for a better then stock replacement. Mintex for a great performance application.
Posts: 2,809 |
Posted by 99blacksesport: I have the exact same problem as you do, SaratogaSVT, on my Non-SVT. have you found the source of the problem? Mine doesnt do it very often, but when it does, boy do I know it cause it is loud! Peace y'all... -Nick Same here. replaced the rear calipers, replaced the e-brake cable, replaced the disks/rotors/pads - nothing. still happens after a cold night - in the morning. this is on my 96 se mtx. my SVT doesn't have the problem.
Posts: 14 |
THANKS FOR INPUT, I TRY REPLACING PADS, BUT THE NOISE I'M HEARING IS COMING FROM INSIDE THE CAR, DOWN BY THE BRAKE PETAL. MAYBE IT'S A CABLE, I DON'T KNOW!?
Posts: 656 |
xplodecontour MTX or ATX? Paul If it's ATX, you might be hearing the Park release solenoid, it can be iterating at times.
