#486760 11/23/02 02:35 PM
Pulleys were instaled today everything worked out ok, the DMD will fit on the new pulley. Belive it or not the engine runs smoother than before, the design though makes me nervous because the crank bolt goes through the new pulley but not through the dampener, the stock dampner goes on using 3 small screws piggy-backing it on the new pulley so the only thing holding the stock DMD on is those screws but I put locktite on them so it should be fine. All in all ive got better low end and a little better mid range power.
Zex nitrous MSDS headers Sho catless-Y Magnaflow mufflers SHO shop flywheel and underdrive pulleys Ford racing P/W 20% tint
ok
eh?
stock DMD
I don't think you're using the right terminology here. The stock damper/pulley isn't usually refered to as the "DMD." So, did you use the stock pulley or the actual Dual Mode Damper?
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
OOPS meant stock pulley
Bascially you traded underdriving the P/S & Alt by ~17% for adding 3+ lbs to the crank pulley (probably a draw) and altering the stock damper's (not a DMD!) orientation & position so it will not function as it was designed to.
The UD P/S pulley is a nice upgrade though.
.... the stock dampener goes on using 3 small screws piggy-backing it on the new pulley so the only thing holding the stock dampener on is those screws ...
Killer:
Could you please help clear up some confusion for us. Did you attach the entire stock pulley onto your new UD pulley -or- Did you remove the dampener from the stock pulley and put it on the new pulley.
BTW: Was this the SHOshop pulley:
Thanks!
the stock crank pulley ataches to the back of the new sho shop pulley,the new sho shop pulley is smaller then the crank dampener
how about some pictures.....
im interested in seeing this setup
2005 Focus ST
I took pictures of the whole install I will post them as soon as I get a chance
