Posts: 29 |
I drove my car (97 contour SE mtx)about 2 days ago, it was fine. Today I got in and noticed after driving for 15mins the heat never came on and the temp gauge was in the red level! I pulled over and opened the hood and needless to say the engine was really hot.
What could have possibly happened? oil/antifreeze levels are good. I have to drive home on Nov. 27th, 4hours...
Posts: 1,412 |
Well, if you have a V6, your waterpump went. Get a new waterpump, but get one with a METAL impeller, not plastic like the Ford ones. I don't know much about it, so I'll let other people chime in. But, if you have a V6, I'm 110% sure it's your waterpump.
Posts: 8,301 |
In reply to:
I agree. IIRC, AutoZone and BAT have the metal water pumps.
-Ken V.
psycho_bass@hotmail.com
Posts: 126 |
definately your water pump, It's really easy to change, (there is a how to post on this site) I actually had to put another plastic one on until I got home to order a metal one. Definately make sure you put on the metal one though.
Posts: 29 |
alright, thanks for the help.
Posts: 6,910 |
I looked into colors of the impeller and if you get a white impeller from Ford you should be in the clear. It seems from asking around that al the impellers that failed are black in color. The white ones seem to have gone into the 99 and 00's, this is why failures are on the 98 and older mainly.
I ask if the metal pump is a good choice. The pump is underdriven off the cam and it is overdriven itself. So is it really a good idea to use a heavier metal pump? Granted it will not fail like the plastic one but the newer plastic impeller should be fine.
- 95 Mystique LS - Zetec/5spd
Posts: 2,061 |
i think u may be right on the color of the plastic impeller...when my waterpump was going (not completely gone but was leaking here and there causing me to go thru alot of water/coolant) the dealer replaced it since my car was covered under used car warr...i asked about them getting a metal impeller pump but that wasn't gonna happen...the service did tell me however that it was a better pump and mde of white plastic...if i can get another 70k on this one im happy...
99 expedition eddie bauer, 5.4 v8, k&n drop-in, 3" magnaflow catback and gas mileage that makes the contour look like a hybrid
Posts: 29 |
yeah, i made an appointment at a local ford dealership. Autozone has the metal impeller for $70. How much do you think for will charge for labor, and how long will it take?
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
When mine went i couldn't get a Metal one but I got the white plastic one.. Didn't have any problems since.
If you have any Mech. ability do it yourself its like a 30min job. 8 bolts IIRC and out and back in its really easy hardest part is making sure all the plastic is out. Mine broke in 3 big peices. But if you can do it yourself it will save you alot of money
Posts: 606 |
Napa carries the metal impellar pump for about $50-55... named "Dura Pro", part #125-1910
'95 'stiqueLS 2.5L ATX
S&B / CTA intake
KEM Mag-Plus wires
1/4" TH fix
Homemade heat shield
Xenon bulbs
Fog light rewire
ATX cooler
Flowmaster 942042
Blacked-out pseudo-chrome
