Page 1 of 6 1 2 3 4 5 6
Shaun G Offline OP
I don't know why he posted this in the dyno section but here it is..
THE CAUSE OF OIL STARVATION
hard to believe... even though everybody knows there's a problem there....As far as i'm concerned, i'm gonna calm down for a while until we get the new dipsticks!!! mad
Anybody knows when Ford figure it out? Was it just recently or it's been a while since....?
Andrei.
98.5 Contour Sport SE,V6,MTX
beeeph.
H
H
I posted it there because of everyones witchen and whining about "put it in the right place" and since it had the word dyno= in it-
'98 SVT #2253
Currently DEAD!
Cobra Paradise
H
H
they have known about the starvation problem from the start-
but why - they just found out about it about 10 months ago and the oil in the pan levels only recently- ie within the last couple of weeks.
'98 SVT #2253
Currently DEAD!
Cobra Paradise
Shaun G Offline OP
well...I'm glad that we finaly have some real research done on this big problem.
I wonder when we will here something from ford?
The normal Ford dipsticks aren't bad enough... wink You need new ones!!!
Oh.. You mean the actual oil dipstick...
2000 SVT #674 - Check it out!
Q
qaz Offline
Q
This isn't the first time Ford had a dipstick problem eek ...I changed the oil in my Mustang 5.0, put in the recommended 5 quarts, and it read almost 1 quart over full. (Yes, I drained both plugs). I posted a message about this to corral.net and someone wrote back saying that:
Ford goofed up on the dipstick.
Since they never bothered to fix it, they issued a TSB stating that the "max" mark isn't really the max mark and it's normal for the oil to be over the max mark after an oil change.
I just used a file to make a new "full" mark after changing the oil and adding 5 quarts.
You have to wonder if maybe Ford goofed up on the dipstick for the Contour, and covered it by specifying a smaller amount of oil rather than doing the right thing which is to redesign the dipstick.
Brian
So how much is the new "recommended" amount of oil to put in? I never knew the recommended amount before this anyway so either one will be helpful...
98 E0 Silver SVT
KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
Joe Offline
Okay, so what do we do.
Manual states oil capacities at:
Engine oil
- with filter 5.5 l (5.8 qts)
- without 5.0 l (5.3 qts)
Should I put ~6.5l in the tour?
Joe, 98 GL sport (V6 MTX)
That's funny because my manual says full is 5.2 litres!
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
