Before you layout for a new EGR, check that the passage AFTER the EGR is clear. The passage feeds EG into three slots in the flange on the intake manifold where the Throttle body mounts. Remove the throttle body, and make sure the grooves around the flange are free of crud, and if you.ve got comprssed air, blow out the passage (cast into the manifold) from the EGR to the the TB flange. If U don't have air, try working a 1/4" piece of rubber hose thru the passage from the egr end to the TB end. You'll be surprised at the crud that gets built up in there! Not a difficult (but messy) job, and if that's the culprit, even a new EGR valve will not help it. Good luck.
'95 Mystique LS -leather, power, Duratech, Auto
-the wife has to drive it too!) -'89 Baby Bronc 4x4 V6, -'84 Honda Shadow
