Posts: 303 |
[Did my Forums search already...]
Do any of you have a problem where, when you car is idling with headlights on, you: a) turn on the rear window defroster and the lights dim, b) turn on the a/c or defroster and the lights dim further? c) rev the engine slightly, the lights brighten until the revs return to idle, at which point they dim again.
Is this a sign of a weak battery or alternator not working 100%?
If not, come on Ford, a modern car shouldn't dim its headlights noticeably when the rear defroster is turned on!
I also notice the instrument panel lights dim and brighten depending on electrical load and throttle position. On nights when I have both defrosters on it's annoying to see the dash lights so dim until I rev the engine!
Anyone? Thanks in advance.
Kerry
99 SVT Contour Silver Frost, #365/2760 91 Isuzu Impulse XS Kammback, Handling By Lotus Victoria, BC, Canada
Posts: 65 |
The car runs off the alt. I would check that out first.
You know you're in trouble when your Grandma flips you off.
Posts: 15 |
if the alternator is not putting out at least 14 volts at idle and the car idles at the correct speed, then i would say the alternator is bad
Posts: 2,156 |
Sam 1998 Contour SVT #180 1/4=14.2 @ 101.17MPH
AOL users = PhatSVT _ _ _____________ _ _
1986 Mustang GT 12 second club
Posts: 770 |
I get the same results on my 99, and my E0 was the same. I think it is normal to a certain degree. Originally posted by kerrychin: [Did my Forums search already...]
Kerry
Andrew 99 SVT
Posts: 4,899 |
I have the highs in the low socket and the headlamps even dim when I hit my turn signals or have the rear defroster on. And especially when the stereo is thumping (it's only a Pioneer HU w/Pioneer 6x8s).
Posts: 74 |
Problem!!!!!!!!! MY dad decided he wanted to clean my headlamps. Fine and dandy with me. The bad thing is we don't know how to take off the headlamps. Any suggestions????
1995 Contour GL Zetec 5spd Airbox removed w/ cone filter added. Tinted windows, VentShades. FUTURE: RIMS!, Power W/L/S, Aiwa CD PLayer, Pioneer Speakers, CTA Intake, Custom Cat-back, SVT BK, WW Touring Spoiler, H&R springs, and graphics by PRO-STYLE Graphics of Orange City.
Posts: 253 |
contour1995 do you mean polish the funky yellowness out of them? this will often require some kind of buffing or polishing compound, i opted for new headlights back in the day when i had my 96 gl. I didn't change the lights myself, but it shouldn't be too hard if you have a haynes manual which i'd recomend. try searching for cleaning yellowed headlights or something like that, it's been discussed before.
don't drink and drive.
Posts: 4,899 |
You might just do better getting a new one for $65 from BAT ( www.batinc.net). That's a steal considering they probably cost double that from Ford.
