#48318 11/23/01 03:10 PM
My Duratec has passed 115,000 miles and is getting ready for a new clutch. Recently, I've starting getting a grind when upshifting from 1st to 2nd at or near redline. I know the synchros are a problem in the MTX transaxles. Anyone replaced synchros yet? Anything available better than stock? Any help/advice much appreciated.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
#48319 11/23/01 08:25 PM
Yep,there is......... wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#48320 11/23/01 09:09 PM
C'mon, is that it Terry? Are they HMS parts?
#48321 11/23/01 09:26 PM
We only sell HMS upgraded parts as part of a trans assy...sorry..
V6 MTX
#48322 11/23/01 09:35 PM
Could you tell me what exactly gets upgraded with your rebuild? When you and I traded e mails earlier this year you only mentioned planetary and side gears.
#48323 11/24/01 06:46 AM
Planetary gears in a MTX?
Jim Johnson
98 SVT
#48324 11/24/01 12:52 PM
The diff gears are often discribed as the side gears (sun) and the diff gears(planent),as when the diff is operating the planets revolve around the sun,same terms in an atx due to the epicyclic gear train(s0.
V6 MTX
#48325 11/25/01 03:54 PM
F
F
My Syncros are bad to..how do I go about getting this upgraged tranny? Terry, are you the one who does it..how much? What will you need? Please let me know..
Thanks
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
