Posts: 157 |
It could be misfire or can be if u have a atx the trans needs tuneup and bad motor mounts contribute also. I say press brake and give it gas if it worse u have a bad plug wire or plug. If the motor clunks it has bad motor mount. If the car erractic doing this the transmission needs attention
99 SVT #198 Blk/blue Grizzly clutch Phantom Grips K&N open Resonator removed BAT 22mm 15.4 @89mph
Posts: 1,861 |
Although the Zetec tends to be a little rough at idle, you can often mitigate it.
Make sure that the engine tune is up to snuff. Especially the idle air control and throttle body. If these are even a little bit dirty, the idle speed may drop a little, enough to agrivate the roughness. Without saying, the plugs and plug wires must be sound as well.
Anything that can interfear with the motors mounts job of isolating normal engine vibration should also be checked. Old saging mounts are a posibility, but not overly likely. Air conditioning lines that are out of position and hitting the body can transmit a lot more vibration than you might expect. Anything that is very stiff that attaches to the engine that is touching the body, including in some cases wire looms.
Sometimes it helps to make sure that the motor mounts are not binding. Loosen the mounts then start the engine and load the engine gently in gear, both drive and reverse, (with you foot firmly on the brake of course) so that the mounts can center and have any stress relieved.
Worn mounts on the engine cooling fan or a fan that is out of balance can make a lot of vibration.
Sometimes, nothing seems to help. You may, however, be able to minimize it.
Jim Johnson 98 SVT
Posts: 1,445 |
i seem to have the same problem...when i first bought the car april 01 it was very slight and only when i would put the car into reverse...it gradually got a little more noticeable but still only in reverse....
well i had my atx replaced at ford dealer and they informed me that two of my tranny mounts were bad...they replaced but i think there is still one that needs to be replaced (how many tranny and/or motor mounts does a v6 have?)...
anyway since i've gotten the car back the vibration is worse and pretty much every gears except park....really rough in drive but goes away when i press on the throttle
when i look i think im seeing two new mounts but the one directly on top the the atx looks like it wasn't one of those replaced so im thinking thats my problem
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 97 |
ANyone know where I can get those Ford Motorsport wires?
+Ford Thunderbird 1997 - V8 +Ford Contour 1995 GL [REST IN PEACE :(][Champagne|ATX] -9mm Ford Racing wires -CTA Intake Kit -Removed exaust resonator
Posts: 1,445 |
im trying to locate some ford wires motorsport wires too....i went to the dealer last week and had to order them and it was some rediculous price....someone from here suggested spmotorsports.com but i think that site is down right now while they change servers
Posts: 97 |
www.zxtuner.com sells some, I just ordered the Ricey Red ones from them.
Posts: 291 |
try this to test if you need new trans or motor mounts,place a floor jack under the engine oil pan with a piece of wood between the jack and pan. gently lift the engine till the strain is off of the mounts. if the vibration stops, you need new mounts. replace them one at a time till you have corrected the problem. start with the one between the engine and the radiator. this one has the most strain. hope this helps.
Posts: 97 |
Putting the car into neutral does help a lot, and eliminates all of the "vibro-mode." I'm gonna see if the Ford Racing wires, once the mailman delivers them, will also help my idle, because mines are kinda old (7 years now).
Posts: 1,861 |
Originally posted by WalieN: ANyone know where I can get those Ford Motorsport wires? BAT, Bill Jenkins, and others that you can find links to on the CEG site.
Jim Johnson 98 SVT
Posts: 339 |
if you are a little low on cash you could get the NGK wires, NGK stuff is suposed to be good for foriegn engines.
91' civic sedan.iceman CAI
