Posts: 109 |
Even with the pedal to the metal it'll shift between 4700 and 5000. What gives??? Oh and this is in drive because I know there's a rev limiter in Neutral at 4000.
95 Mystique LS V6 ATX "Your on a need to know basis and you don't need to know" THE ROCK
Posts: 9,178 |
I thought the rev limiter was 3500 in Park and Nuetral.
Posts: 1,479 |
The ATx will "learn" how you want to shift. But it takes time. My '96 LS v6 Mystique was not shifting high enough so I would shift manually with the shift lever for awhile and that would get the shift RPMs up. The autotranny will NEVER (on it's own) shift at or anywhere near redline... That's what the shift lever is for. 1 2 drive.... I know it's hard to shift into 2nd and not slide right into drive.... when you are excited... I was thinking of a pin?? or whatever to hold it to 2nd so I could slam it to 2nd and not worry about skipping right into drive. I bought a '99 SVT so I don't have that problem anymore.
One beat'99 Tropic Green SVT
Posts: 1,181 |
Originally posted by Elizabeth: The autotranny will NEVER (on it's own) shift at or anywhere near redline... That's what the shift lever is for. My ATX doesn't seem to have a problem shifting at 6500-6750 RPM on its own
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Posts: 708 |
Originally posted by Antiramie:
My ATX doesn't seem to have a problem shifting at 6500-6750 RPM on its own  Ditto.
Ryan French
98 Mystique Duratec Sport(KKM, Custom Exhaust, debadged/dedinged, Tinted, A4 sidemarkers(clear), Bodycolor grill...Suspension is next.)
00 ZX3 Zetec Limited Edition(nothing)
Posts: 89 |
mine goes to just under 7k, probly about 68-69. alot less in second(6500), unless i shift manually.
Black '98 Mystique V6 atx. superchip,2 1/4" SVT style dual exhaust (custom) with no cat, high flow res, flo-pro mufflers with Ractive tips, 8.5" K&N conical with CTA adapter, UR Ultra Street Pulley, TH-fix. 215/45/17 Bridgestone RE730's on Konig Absolute wheels. Trans go Shift Kit, High stall torgue convertor, 24000 BTU transmission cooler.
Posts: 2,607 |
ummmmm my atx redlines just fine... you sure about that one?
andy watson on my 'Beer Goggle' Post: AureiusX: You needlessly made an ass of yourself JenovaFire: it was a good idea at the time AureiusX: LOL AureiusX: so was she
Posts: 123 |
My friend had a Ford Tempo (I kow POS) that suffered the exact same problem (except the hardline was 4000 RPM.)
It turned out to be the programming in the PCM. They swapped it out, and everything ran fine. BTW, there original PCM did not throw the MIL/CEL when it went bad.
Nothings perfect.
Good Luck, David
2000 SVT #669 Wimpy Stock stuff
Posts: 109 |
Well I guess I better teach it then. When I got the engine replaced about a month ago I drove it like a baby but lately I wanted to see what it was made of and been punching it so that could be why it's not shifting high. My boss has a 2001 BMW 330 ci and she said that it has a chip that customizes the car to the driver's habit's (shifting, cornering) Is there something like that in my car? :rolleyes:
