Page 4 of 6 1 2 3 4 5 6
Originally posted by Rara:
Why must so many people confuse boost threshold with lag????
Because half of the people don't know what the difference is? Ding ding! do I get a prize for the correct awnser?
what is the difference? I'm turbo illerate.
Ryan Trollin!
"Absolut Rara."
"Absolut Rara."
True turbo "lag" is purely a throttle response issue. To see lag, sit at steady state, at some rpm above the boost threshold, and nail the throttle, the time it takes to reach full boost is lag. Lag really isn't determinable by a typical dyno curve.
Boost threshold, is an rpm level, at which the engine is finally making enough exhaust energy to spool the turbo properly. ie, stomp the throttle at 1500 rpm in just about any car, and it won't make boost until it gets above the boost threshold.
It takes exhaust energy to spin a turbo, some heat, some pressure, some velocity, if you don't have enough exhaust energy, the turbo just won't spin fast enough to make "boost" . On a similar note, a wastegate, simply bleeds off the extra exhaust energy (routes it around the turbine) once the desired intake pressure level is reached.
That said, if you want high horsepower at the top end, you want a turbine and housing that can use every bit of exhaust energy at that higher rpm. A turbine housing that can make use of all that exhaust energy, is typically too large at the lower rpms, so you end up w/ a higher boost threshold than you otherwise would.
That is the case here, Turbo Tom desired a turbo that would make better use of the exhaust energy at the higher rpms, and therefore build more power, so he must take the tradeoff of the higher boost threshold. Or actually, if I read an earlier post correctly, he desired the higher boost threshold in order to make the best of his limited traction situation. Whatever floats your boat; its all good as long as things work out the way you designed them too.
Balance is the Key. rarasvt@comcast.net
Very informative Rara, as usual. I learn so much every time I browse these forums.
~~~~~~Mike~~~~~~ Black 2006 VW Rabbit Silver 2000 Contour SVT - SOLD ~~~~The Car~~~~~
1
1
Very well said Rara
I went to the 406 gear because i am going to a set of 26x8.5 tires. If i stay with the stock 382 gear and the 26 tall tires that would not be enough gear
tom
Originally posted by Keyser:
Sooo...what size/brand turbo is it?
2001 Lincoln LS8 1994 Lexus GS300
"Absolut Rara."
"Absolut Rara."
Originally posted by 1turbofocus:
Very well said Rara
tom
you might be interested in this then, I was talking w/ Leo Capaldi today (of the Capaldi Racing Cougar) he says they have a 4.5 gearset for the MTX-75
http://atomicinternet.homeip.net/capaldiracing/store.asp
E
E
I believe Tom is keeping the specs "hush-hush" at the moment.
Bill P. 01 LG ZX3 S2 Quick Enough.
What are we going to do steal it? It's harder to sell a turbo kit if you won't say what kind of turbo comes in it.
Key, the turbo he has in there now isn't the one(to my knowledge anyway) that comes w/ the kit he is selling....
-J
'98 4Runner
Moderated by  mbb41_dup1
