Posts: 1 |
Anybody ever had a problem with a leaky trunk?? I have a 99 SE. It seems to me the water is sneaking around my weatherstripping, but I took it to a dealer and they are telling me the tail light is leaking. I can't find a leak in the tail light...
1999 Contour SE 2.5 V6
Posts: 1,861 |
Get a flashlight and a trusted friend and look for the water leak. Climb into the trunk with the flashlight while your trusted friend runs water from a hose all around the trunk and tail lights. Usually you can find the leak this way with a little patience.
Trunk seals can leak, and so can tail lights. It is all speculation until you test it.
Jim Johnson 98 SVT
Posts: 198 |
I found a leak in my 95 contour which was in the trunk. Apparently the inter panal within the trunk has a retangular plug that fits into the panel to plug the mold hole from factory. The one that was there cracked and fell out allowing water to enter the trunk around the tail light.
Posts: 105 |
Leaks at the tail light gasket is quite common. I had the same problem.
Posts: 200 |
i work at a ford dealership, and we've had a couple of contours come to us with a trunk leak. Each one was infact the tail-light.
96 Mystique "Spree" Duratec ATX ---------------------- "They have the Internet on computers, now?"
Posts: 3 |
My 95 Mystique leaked around the tail light. They replaced the weather stripping around the tail light and voila no more water dripping on my head when I reach in to get my groceries. This was apparent within about 6 months of buying the car new. Judie
Posts: 417 |
Mine leaked at the fresh air vent box just infront of the tail lights. Pull your trunk liner back, it's about 6-12 inches infront of the tail light. To check it blast some water up in the vents (you'll see the slits just infront of the tail lights)
99 Ford Contour SE Sport Manual V6 SVT front/ rear bumper /w Aussie grille Jet black Premier DEH-P740MP head unit matrix display, plays Mp3s!! 800 watt Kenwood amp 2 12" Polk Audio subs Blue "euro" headlights Eibach Pro-Kit springs 17" Enkei RS-5 White Indiglow gages
Posts: 974 |
Get some of that black RTC or whatever and put a fine bead over top of back light assembly. Mine was noticeable shrinkage of that black seal. After black bead (no me problem) $7.00 at hardware store!
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
Posts: 1,181 |
Originally posted by Big Jim: Get a flashlight and a trusted friend and look for the water leak. Climb into the trunk with the flashlight while your trusted friend runs water from a hose all around the trunk and tail lights. Usually you can find the leak this way with a little patience.
Trunk seals can leak, and so can tail lights. It is all speculation until you test it. Haha, or make sure u have a 4 button key fob!
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
