I expect he is not using the normal offering of the center muffler with two outlets, right? As the is no way in hell you would get two 3" pipes around the gas tank, not without on being vertically above the other which would hang you exhaust WAAYYYY low.
He is going "Camaro-style" too?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Originally posted by Keyser: Don't you have to multiply by 3.14 to get volume anyway?
No, Pi is used to get area. Area = Pi multiplied by the square of the Radius. Pie are squared... get it? LOL! To get volume, take the computed area times the length of the tube.
http://www.bnmotorsports.com
I checked Yodude's website, they use 1 muffler located in place of the factory resonator, 1 in 1 out, then the "y" split to dual tips. You guys think I'll experience any drone with a single Magnaflow directly under the cab?
2002 ZO6...462whp/410wtq
pretty darn fast!11.70 @ 122
silver/black
2006 Trailblazer SS(wifes car)
silver/black
2000 SVT-Turbo-sold
silver/blue #1699/2150
13.83 @ 102.82 on 5psi
13.51 @ 107.56 on 8psi
NBot as long as it is Long enough and has enough volume (you want 1.5x volume of engine as rulle of thumb) ~3.75L=3750cm^3 I would go for the longest 5x8" Magnaflow I could find in 3", which is 24" long. Part number in case you're interested is 12279.
AUSSIE ENDLINKS $70
All this talk about Pi is making me hungry.
George Hodge
New: Volvo S60R
Old:2000 SVT Silver Frost 1188/2150
DMD, 75mm Pro-M, HPP rear strut tower bar
Aussie 24mm sway bar (with boxed in subframe)
BAT European Handling Kit, Brullen Y-pipe
Performance Ford spherical bearing end links
