Posts: 2,523 |
Originally posted by Chris Hightower: Do you need the specs for that transistor? Is it fried (illegible) or just malfunctioning? Don't know about JPett's, but mine has no obvious signs of damage (i.e. frying). If you have those specs, I know I would appreciate them I have to go to Radio Shack anyway once I find out about this IAT resistor mod Kaiser just told me about
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 291 |
seriously, easy fix, go the the salvage yard and wander around a contour, pull out the clock from the dash and unplug it's pin. Problem solved. oh, pay for the part too!
Posts: 2,523 |
Nevermind. I'm a moron. Turns out I had put the bulb in upside down. All's well (talk about embarassing)
Posts: 3,165 |
Originally posted by Chris Hightower: Do you need the specs for that transistor? Is it fried (illegible) or just malfunctioning? Yes, I would like them spec. too if you have it handy. Thanx! It's malfunctioned (shorted) and it's days are through.  My dad is going to try and replace it, hopefully it will work right for this application. We'll see. just seems kind of silly to throw it away and get a new one when it might be fixable.
Posts: 9,178 |
Originally posted by D Davis: Nevermind. I'm a moron. Turns out I had put the bulb in upside down. All's well (talk about embarassing) HAHA That makes me feel smart.
Posts: 2,523 |
shutup
Posts: 9,178 |
Originally posted by D Davis: shutup  Sorry I have to point out other's mistakes so I feel better.
Posts: 97 |
Don't make D Davis feel TOO bad: it takes a contest of wills to make it go in right the first time, and if you don't expect its stubborness...
Black/tan early '98 Contour SE Sport; V6, MTX, loaded Kenwood KDC 316S CD deck; aux. dome light mod; trunk popper spring; resonator bypass; hood strut mod; SVT grille; Continental tires Mom also has black/tan '98 Mystique LS; V6, ATX, Alpine CD deck
Posts: 3,165 |
Yea!!! My clock is fixed!!! Here's a link to show what my dad did to get it lit up again. clock fix the cause-- a fried tansistor.
Posts: 3 |
My clock is also not illuminated. Ok I will replace the bulb. But, I have a 95 Mystique. It looks like the whole plastic trim piece around the clock/ speedo/ gauges has to come off. There are 4 screws on the inside bezel around the gauges. Do I take those out and then the whole plastic bezel falls away? I have not noticed any other screws.
Judie
