Posts: 22 |
IS IT HARD TO CHANGE THE GASKET FOR THE INTAKE MANIFOLD???? CAUSE I THINK I HAVE LEAK CAUSE I AM RUNNING LEAN(1 BANK LEAN) AND SOME ONE TOLD ME THAT I HAVE A LEAK IN THE INTAKE MANIFOLD SO IS THAT RIGHT? IF SO I AM GOING TO CHANGE IT...HELP ME OUT IF U KNOW....
Posts: 1,210 |
Did you just put a different air filter on?
One time when I changed my airfilter I forgot to reset the ECU and put my IAT sensor in and I got the code Bank 1 lean
donno if it helps but just keep in mind
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Posts: 22 |
yea i change the filter(whatever you wanted call it) but thats it,no cold air or anything just he filter... i have an open filter... and when i did that, then thats when it started to do that....
Posts: 1,943 |
i think it says somewhere in the archives that if u use caps lock a lot u can get that CEL
the 3.0L
oval port 3.0L '98 midnight blue se
Posts: 1,210 |
I would just reset the computer by pulling the negative battery cable or pulling fuses 4 and 11 (I beleive?) and see if it comes back again
Watch me go
Posts: 41 |
I got the same Code for a leaking valve cover gasket
Posts: 1,044 |
A weak O2 sensor can cause a CEL code for this. The intake manifold gasket is possible, but I think you would have other symptoms beside just a CEL. If the car idles & runs smooth, an O2 sensor might be going out. Bank 1 is next to the firewall. Harder to reach, but do-able in an hour or so.
P0171 System Too Lean - Bank No. 1.
Posts: 1,516 |
Originally posted by tw0wheelin: A weak O2 sensor can cause a CEL code for this. The intake manifold gasket is possible, but I think you would have other symptoms beside just a CEL. If the car idles & runs smooth, an O2 sensor might be going out. Bank 1 is next to the firewall. Harder to reach, but do-able in an hour or so.
I think if an O2 sensor is going out you would have a slightly inconsistant idle. That's what happened when mine went out.
Mazda 6S, V6, Speed Yellow
5 Speed, Sport package
Bose audio
Painted 'stash and HIDs!
w/Injen 1/4 14.750 @ 94.94
Former car:
99 Contour SE Sport Black MTX V6
SVT plastic...
1/4 - 15.012 @ 90.58
