Posts: 98 |
So after searching, if I understand correctly, the problem impeller is the stock black one, and a tan plastic is mentioned as a better designed replacement unit, right?
So what is the white impeller? Any good? I'm going to replace my stock unit soon and I'm trying to decide between the Autozone metal unit @ $70, and a new ford part with the white impeller that I can probably pick up for $30 or so. (Depends on how an auction goes.)
At that price would it be a good bet, or should I go for the metal unit?
Thanks, Dave
98.5 SE/sport/MTX Brembo rotors w/KVR front and Mintex A/F rear Pro-Flow 75mm MAF w/KKM filter-Nice! Mobil 1/K&N oil ES MM inserts waiting-I can't get the bolt loose...need a bigger breaker bar:( Aussie Bar and Euro ST200 struts soon! Major mods to stereo system Clarion 9255 All Phoenix Gold processors/MPS amps! Vifa/Adire drivers
Administrator
Administrator
Posts: 702 |
Go for the metal one -- you'll never have to replace it ever again. Plenty of folks have broken the new white ones, too.
-Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 3,419 |
Originally posted by Lance Kinley: Plenty of folks have broken the new white ones, too.
-Lance Really? I've posted multiple times asking if anyone had busted the white one with no response. I put the white one back in my 3.0 because I couldn't find any evidence of white ones crapping out. Of course, if mine breaks, shame on me for trying to save $60.
Posts: 12 |
Does anyone know if all Autozone replacement pumps come with the metal impeller? I had my water pump replaced a couple of weeks ago and I'm not sure what part I ended up with, but I do know that the shop buys from Autozone regularly (next door). Unfortunately, I didn't have time to do it myself...doh!
Cason Houston Silver E0 - new water pump, replaced sunroof motor assembly, antenna at half mast, non-working lumbar motor, ocassionally non-opening secondaries. Hmmm...
Posts: 7,329 |
The waterpump is made by GMB #125-1910
Costs like $55-60
Posts: 98 |
Thanks for the replies. I think I'll go for the new metal. The bid is up to $30 or so now, +$15 s/h so it isn't much cheaper either. Dave
Posts: 638 |
I know this reply is probably a little too late but if you haven't bought the metal impellared water pump, I don't suggest it. I put one in my car a few months ago after my factory pump died on me at around 38k. Since installing the new pump, my temp light comes and goes and the temp guage gets too high when I'm at an idle. The only way to get it back down is to turn on the a/c. I think that the blades on the metal impellar are too shallow to push enough water through to keep it cool at low rpms. Anyway....if anyone has any suggestions, I'm open. Thanks.
'98 Silver Frost SVT FOR SALE muffler/resonatorless AOL IM- SVTcop Yahoo- countryboy_tx ICQ-8981296 / 111560813 JOIN THE N.TEXAS Ford Perf Club. WWW.SVTTEXAS.COM
Posts: 179 |
SVTcop, i don't know if this is any help. A friend of mine had his car running hot and turned out to be an air lock. Air not bleed completely out of the cooling system.
1998 se v6,auto purchaced from Ford certified used cars on the web at 14,100 mi. june,2000
Posts: 3,419 |
How would one go about ensuring there was no air in the coolant system? Your friend's situation sounds a lot like my current temp situation.
Posts: 3,567 |
buy the metal one, it will last a long time.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
