Quote taken from the FAQ section:
"The first time I started it, the engine "hunted" before stabilizing at 750RPM idle.
Did this when the lights were on and the AC. The ECU is learning the new
position of the valve for maintaining the programmed RPM, which is normal. After two or three starts, it acts normal."
Did you do this when resetting the computer? I did and have not had a problem(going on 2 years) since. I would consider the TH fix a priceless mod, saving me from the embarrassment of the moose. RIP Ray
