#476227 11/08/02 08:13 AM
Where can I get a hygrometer and about how much does it cost?
#476228 11/08/02 10:57 AM
H
H
You can usually get a hydrometer for coolant or battery electrolyte testing at the same places you would buy antifreeze or batteries; i.e., auto supply stores, Wal-mart, etc. I'd guess they start under $10. for DIY type, more for a pro model.
If your battery has a "glass eye" its already got one built in.
#476229 11/08/02 12:49 PM
As mentioned above, you can get them at Walmart, Trak Auto, etc. for about $4.00.
