Posts: 69 |
My SVT is starting to develop a ticking in the engine. it is getting slowly louder and louder and I have a feeling it is a valve issue or leak in one of the exhaust manifolds. Anyone else experience this.
98 EO #587
Currently Dirt Jumping
Posts: 5,854 |
most duratecs have some sort of "valve" type noise, either the timing chain rolling over, noisy injectors, exhaust or belt tensioner, etc. If it's getting louder however, that is not good. Is it coming from the bottom end? You should be able to discern from a tap and a knock. Knock = bad. Do you change your own oil? Tear apart the filter, see if there's metal shavings inside. Or j ust get it back from the mechanic next time you get your oil changed. Keep us posted.
1999 Silver Frost SVT
#609 of 2760
Posts: 3,110 |
could it be the throwout bearings in the clutch?
(do i have that right????)
Hugo
98 SVT - 53k mi - SOLD
04 Mazda3 S 5-Dr
Posts: 5,854 |
if it doesn't make the noise when the tranny is in neutral, then it could be gear sounds fro mthe MTX. But, the only noise i've ever heard from a bad throwout bearing is a high pitched whine, which I am developing now
#609 of 2760
Posts: 1,516 |
Originally posted by TheGreatOne: if it doesn't make the noise when the tranny is in neutral, then it could be gear sounds fro mthe MTX. But, the only noise i've ever heard from a bad throwout bearing is a high pitched whine, which I am developing now
How bad is that?? Mine has a slight whine when I'm at WOT
Mazda 6S, V6, Speed Yellow
5 Speed, Sport package
Bose audio
Painted 'stash and HIDs!
w/Injen 1/4 14.750 @ 94.94
Former car:
99 Contour SE Sport Black MTX V6
SVT plastic...
1/4 - 15.012 @ 90.58
Posts: 5,854 |
You can hear something other than the engine at WOT!? I notice it if i'm downshifting to 1st say at a stop light or something...or if i'm coming to a stop and just put it to 1st with the clutch in to get ready for the light to go green. It is my understanding that when the throwout bearing goes bad you will have problems disengaging your clutch.
#609 of 2760
Posts: 69 |
Been gone for awhile. I took a few 100 mph passes, changed the oil with Amsoil 5w 20 and added 8 oz of miltec to the oil and all my noises are gone. Thanks for the replys. By the way, the tapping was from the top of the motor. I'm thinking a sticky valve spring or something like that. As for my choice of oil, you can't go wrong with Amsoil and the weight, well that is debate. Miltec??? great stuff. It's weapons grade lube.
98 EO #587
Posts: 319 |
Originally posted by 2112: Miltec??? great stuff. It's weapons grade lube.
yeah but, is it worth the money?
1998 Contour SE
Panasonic CQ-DFX683
Sound by Crystal Mobile & Illusion Audio
Powered by Alpine MRP-F240, Alpine MRP-M350
My Ride
Posts: 69 |
Yes, the stuff is really expensive and does work really well. I even have it in the tranny and Power steering pump. But you don't have to try it if you don't want to. It's just something to try that is proven by all the high end Ford motor heads I know.
98 EO #587
