Posts: 168 |
Just a general question about the electricity going through these Duratec alternators. I had mine rebuilt for about $150...needed a new transistor, and two other parts I couldnt even pronounce. The guy said he had to RESOLDER the connections to the alternator again cause I melted it so bad. I feel kind of proud in a way. I'm only running a small Legacy Audio amp that only puts out about 80watts RMS. I don't currently have a fuse on the power cable from the battery to the amp. But I also have 9mm Ford Motorsport wires going to Bosch Platinum +4s. So I was wondering, since my sparks are being driven by high performance parts, does that put a damaging amount of strain on the Duratec alternators? Thanks guys.
Ryan M. Taylor 1996 GL V6 ATX Desert Violet {__ 15" 98SE 12-spoke wheels, 205/60-15 Pirelli HP Unidirectional Tires __ KKM TrueRev Intake __ Bosch +4's __ Pioneer DEHP4000 __ 9mm Ford Motorsport Wires __ 2.25" Dual Exhaust, Catco Cat, Flowmaster 40 Series, no res __ Mobil 1 5w30 badge mod __ Pilot Millenium Series H.I.D. 55W Fogs __ Xenon 100W Highs __ Intermittent Ford P0420 CEL Option __} http://rmtaylor.webhop.org AIM: Vinnland990
Posts: 1,969 |
Dude...
Two words and a hyphen.
In-Line Fuse
Kharma is very real and she is one mean b!tch.
Posts: 559 |
Alternator has nothing to do with Spark Plugs or Ignition Wires. Just keeps your Battery happy.
99 SVT Black/Tan #1090/2760 82K Miles.......B&M Edge Shifter Mobil1 5-30.....Side Markers Ford Synth MTX # XT-M5-QS Locking Lugs....Cup Holders Black Sail Panels...TH Fix Aluminum Gas Filler Door BS Potenza S-03's KVR Cross Drilled Rotors + Pads Dual Mode Damper - soon Clarion head unit Pioneer 2-ways
Posts: 974 |
Second the fuse thing. Cheap and you can buy a dozen as extras!!!
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
