Originally posted by Specialist23:
i have a leak somewhere. they tested everything and said that they found nothing. the leak is coming from the driver side of the engine. i'm thinking that it's some type of "tranny" leak or something that would be over there. it's not red and feels like water.
Spec,
Are you sure it's not just water from the air-conditioning system? I remember when I was in Minnesota there would be a puddle of water under the car whenever I had the A/C on, probably due to the humitidy. Although it's cold there now I think, so if you haven't had your A/C on lately and still see the liquid, I'm out of ideas for you. Oil is carmel/black, brake fluid the same, sometimes red, like power steering fluid. Maybe it's a coolant leak? Anyway, best luck trying to diagnose it.
Terry:
It's not the transmission or clutch, from what a couple friends and I think. If I take off the airbox to get a clear view of the transmission, there's this weird, plastic, rectangular object that the shift linkage kind of 'hooks' into at the top of the tranny, which has an extreme amount of play and I think when everything gets hot, it's that plastic piece that's causing all of the problems. Any idea what I'm talking about?
I tried to find a parts book for our cars to get a name for that piece, but no luck so far and the dealership can't look at my car until mid-next week.
Hope that info helps.
Matt
