#473765 11/05/02 02:21 AM
i was wondering if the lower intake mankifold and 19 lb injectors off of svt make a difference on 96 se?
96 se with svt ground effects and pre 98 svt front bumper, optimized tb, svt maf w/svt intake, daul exhaust, with no main cat,resonator, svt gauges and short shifter,reverse lockout removed,e1 svt rims
#473766 11/05/02 03:01 AM
The LIM is Not a direct swap because of the different fuel rail/injector setup.
The injectors are not advised unless you are at the point you need the entra fuel. (~165FWHP) Then get a new MAF too.
#473767 11/05/02 04:22 AM
check HERE as someone is attempting this and encountering the issues DemonSVT was talking about.
Hugo ------ 98 SVT - 53k mi - SOLD 04 Mazda3 S 5-Dr
#473768 11/05/02 11:29 AM
so basically i just need the fuel rail and a couple of inches of fuel line? sounds easy enough,
