Page 3 of 3 1 2 3
rangers also had 2.3L engines with 70hp.
2
blackie, my bro, has the tbird turbocoupe. which has the 2.3 turbo from 83-86 no intercooler and T3 turbo(spools up slower than IHI)165 stock, then 87-88 they had an intercooler and IHI (spools fast to motivate 3300lbs) 190hp stock, nick(blackie) with a k&n and boost controller and no spare hit a 14.9 thanks to 18 psi!! stock they hit 9 psi and ran a 15.7 according to motortrend. The mustang SVO came with a T3 and an intercooler and had 205 stock, some guy in mustangs and fast fords had one with no nos pushing 450 hp not trying...me jealous
Derek Johnson 88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3 95SE 3L gone
CEG road warrior
CEG road warrior
Originally posted by 2000v6SE:
Yeah I had a Z, was fine.
But, what do you Z'ers think of the new 2.3L DOHC engine coming to replace it? 170 HP w/o a turbo and should kick Honda is the a$$. It's now in the 2003 Ranger and Mazda 6i.
And please, no "Pinto engine" comments.
The Duratec v6 only has a bad water pump before 1999, and it is now upgraded, in the Mazda 6s with 220HP. Should be in the C/D338 "Tauri/Contour replacement" for 2005, also.
Ranger DOES not have the 2.3 with 170Hp. I saw one at the track run 18.6 with a MTX. That 2.3 is a Mazda engine not a Ford, just like the Mazda Protege has a 2.0L and is not a Zetec.
the 2.3L engine replacing the zetec in foci is a mazda engine.
Wasn't the Mustang SVO engine designed or made by BMW?
#473561 11/11/02 05:30 AM
Y
Y
"the 2.3L engine replacing the zetec in foci is a mazda engine."
Yes, it pretty much is, but then the Protege platform will be repalced with the Focus one, in 2005. But, then again, Mazda is controled by and 34% owned by Ford.
More parts sharing is the present way car companies are doing business.
2005 Nissan Sentra 1.8 SE, Code Red. '00 Tropic Green Ford Escort SE [Contour's little cousin]
#473562 11/11/02 05:39 AM
how come they 're not using the 4cyl duratec 2.3L in new foci? not strong enough?? and gm has some nice new 4 and 5 bangers out based on the vortec. they have some very respectable power.
#473563 11/11/02 06:07 AM
In reply to:
5 banger???
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#473564 11/11/02 09:17 AM
Originally posted by CRZYDRVR:
In reply to:
5 banger???
check out volvo thye got some too....
2003 Subaru WRX some mods Even if you don't have the answer, you certainly have to admire the problem. aka ZetecRacing
Page 3 of 3 1 2 3
Moderated by  Loco4G63
