Posts: 21,653 |
rangers also had 2.3L engines with 70hp.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,055 |
blackie, my bro, has the tbird turbocoupe. which has the 2.3 turbo from 83-86 no intercooler and T3 turbo(spools up slower than IHI)165 stock, then 87-88 they had an intercooler and IHI (spools fast to motivate 3300lbs) 190hp stock, nick(blackie) with a k&n and boost controller and no spare hit a 14.9 thanks to 18 psi!! stock they hit 9 psi and ran a 15.7 according to motortrend. The mustang SVO came with a T3 and an intercooler and had 205 stock, some guy in mustangs and fast fords had one with no nos pushing 450 hp not trying...me jealous
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by 2000v6SE: Yeah I had a Z, was fine.
But, what do you Z'ers think of the new 2.3L DOHC engine coming to replace it? 170 HP w/o a turbo and should kick Honda is the a$$. It's now in the 2003 Ranger and Mazda 6i. And please, no "Pinto engine" comments.
The Duratec v6 only has a bad water pump before 1999, and it is now upgraded, in the Mazda 6s with 220HP. Should be in the C/D338 "Tauri/Contour replacement" for 2005, also.
Ranger DOES not have the 2.3 with 170Hp. I saw one at the track run 18.6 with a MTX.  That 2.3 is a Mazda engine not a Ford, just like the Mazda Protege has a 2.0L and is not a Zetec.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 21,653 |
the 2.3L engine replacing the zetec in foci is a mazda engine.
98.5 SVT
Posts: 682 |
Wasn't the Mustang SVO engine designed or made by BMW?
Posts: 2,580 |
"the 2.3L engine replacing the zetec in foci is a mazda engine." Yes, it pretty much is, but then the Protege platform will be repalced with the Focus one, in 2005. But, then again, Mazda is controled by and 34% owned by Ford. More parts sharing is the present way car companies are doing business.
2005 Nissan Sentra 1.8 SE, Code Red. '00 Tropic Green Ford Escort SE [Contour's little cousin]
Posts: 21,653 |
how come they 're not using the 4cyl duratec 2.3L in new foci? not strong enough?? and gm has some nice new 4 and 5 bangers out based on the vortec. they have some very respectable power.
98.5 SVT
Posts: 8,301 |
In reply to:
5 banger???
-Ken V.
psycho_bass@hotmail.com
Posts: 3,465 |
5 banger???
check out volvo thye got some too....
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
