Page 2 of 2 1 2
Don't know the year - they were an ebay set from fiveomotorsports.com (something like that) here in california. Maybe something like D5E-FOTE, I have two extra floating around at home somewhere so I could check if you want to know.
97 Contour SE MTX K&N 3530, UR UDP, 19# Injectors, mystery mod, FMS wires, Fordchip.com chip, SVT: TB, Flywheel, clutch, exhaust 04 Grand Caravan SXT
Redneck Troll
Redneck Troll
The 5.0 FRPP crate motors use the orange one pictured here:
9
9
just an update for anyone do SVT/ST200 UIM & LIM install
note
install gas pedal cable before you putting intakes back on gives you more room to get it in there.
note
spend 20.00 more at put all new fuel injector o-ring seals so you don't have to take it back apart 2 or 3 times for leakers.
note pre-98 installs
completely remove the injector clips before removing harness or they will go flying
you need to flip your injector plugs over in harness
i have 2 good pic of the right fuel needed for anyone doing SVT/ST200 UIM & LIM install on pre 98 so you can send it to junk yards to make sure you get the right one
mine was 75.00 plus S/H for rail and injectors and harness.
pm or email if you have questions
I now to can help with this mod been there done that
97_contour _sport Added T-red wing Cougar big brakes DMD pulley SS brake lines Ford 9mm wires 21mm BAT bar SVT motor mount ES bushings Metal water pump ST200 badges & mats ST200 UIM/LIM Cold air intake BAT Y-pipe
Page 2 of 2 1 2
