Well as most of you guys know, my car is in the shop for what I think is a bad differential!!! The shop says they think it is the "spider gears". However I had some parts of my tranny replaced about 6-7 mounths ago so if the broken part is one the ones the replaced before it falls under the ford parts warranty!!!!
These are the parts they replaced previously:
f7rz7005BA Case-Transaxle Clutch 248.80
f5rz4026FD
Differential ASY-Transaxle 169.48
f5rz7f343BA GR-trans FNL DRV RG 220.22
2 f5rz1177AA seal-Transaxle Diff stub shaft 8.25
2 f5rz4221ac Bearing Asy-axle Diff 18.04
and there are a few other parts I can list if needed...
Now my question is: are the Spider gears located in any of the parts listed???
I am guessing there located in the Differential Asy-Transaxle, but I am not sure
The reason I ask is because I am expecting a battle from the shop and want to be prepared!!!
Thanks again
