#472148 11/01/02 07:37 PM
I have a 1998 contour se with the duratech engine. I have heard the transmissions are troublesome on these cars. Is this true? I have heard alot of them go at 80-100k i have 65 now. What do you all think about this? True or False? Oh yea i have a automatic trans.....thanks
-Jason
Jason 00 Audi S4, 2.7 Bi-turbo quattro 01 S10 Xtreme, 4.3l 98' Contour SE with some mods 96 Cavalier (beater)
#472149 11/02/02 02:48 AM
Well, I dont know how bad these transmissions are but I do know that I have 170,000 kms on mine and it still works fine.
#472150 11/02/02 05:48 AM
U
U
I got around 150,000 out mine. Bear in mind that I only owned it for 25k of those. These trans fluid was in bad shape when I bought it. I changed it once (drian and fill 3 times) & one other 12,000 after that. After the first fluid change I added a bottle of Slick50 HighMilage to it.
At 150k, the chain broke. This was not caused by ill service. I posted a link here (you might have to search the archives) on a TSB by Carquest on this topic. The collar on the drivers side CV Shaft wore out. This caused misalignment between the main drive gear and the Overdrive Plantery gear. In other words, slack on one side of the chain and over tight on the other. Simple cause and effect.
I knew of many problems with the ATX's on this car, but most of them was before the filter redesign. Check out Filtrek for info on that.
As I have learned over the years. If you don't sweat it, you won't loose it!
Phillip Jackson
Smithville, MS
98 Mystique LS
Stock as of now, oh but you just wait!!
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#472151 11/04/02 07:26 PM
Sounds good and thanks for the input!
