Page 2 of 4 1 2 3 4
i have 17's in a 98 E0 and i pulled 168hp 152tq. not the best numbers considering the mods i have but i'm working on it.
if we could see the graphs, we might be able to help out.
Hugo ------ 98 SVT - 53k mi - SOLD 04 Mazda3 S 5-Dr
Originally posted by svttour2000:
I go to UTI and today we had dyno day, My 00 svt contour pulled 150 hp and 138 tq, I dunno why it was so weak but I was really dissapointed, most guys dyno round 170 or so right? considering that i should lose 18% throu drive train. I really think this could be the beginning to a long story starting with a new clutch and nitrous, but we'll see
God All Mighty I feel for you
RamMotorsports Lowest prices on SPEC Clutches and Flywheels
Well I can "kinda" relate to you here, as I pulled 159 hp last year at SZ. I had an open K&N, gutted pre-cats and true duals. Then almost a year to the date, I dyno'd again and this time I pulled 168 hp, w/o any mods Although it wasn't at the same dyno shop, it was the same dyno, which was the famous DynoJet. What type of dyno did they have
Anyone notice that a lot of the 00 CSVTs are dynoing low? Almost everyone I've talked to with a 00 is lower than previous years.
-R-
I'm a Karate Man. Karate men..bruise on the inside. "The difference between oversteer and understeer: oversteer is when the passengers are scared, understeer is when the driver is scared." -Driver Unknown
-R-
Actually they dyno higher.
-R-
No. I hit 184, 185 for Derek, Demon is estimated near 200 and Erik is over 190. I think those are higher than other years.
I have Derek's chip program on file if you want to try a copy.
2001 Lincoln LS8 1994 Lexus GS300
No, no, no, no. I don't think you understand what I meant. It's obvious that they seem to be taking to mods better. But stock the #s seem to be a bit lower. I'm not saying all of them. I've just noticed some lower stock hp #s with this model year.
-R-
er, just to through this out there, and Ithink you were joking, but N2O is only going to make your hp numbers worse if your engine is not running correctly.
Otherwise, I'd start off on what others have said. Clean the UIM/LIM, check the precats/cat etc.
Ryan Trollin!
Yes Its been a while and I almost forgot about this thread but it was my caltalitic converter and an IMRC failure combo, I need to find a dyno and see what she pulls now.
2000 Black SVT CONTOUR #283 OF 2150 04 Honda Cbr 600 RR (candy blue) http://members.cardomain.com/svttour2000_03
E
E
Wow, 150 HP without the secondaries opening. That is pretty damn impressive. I wonder what your numbers will be now that everything is working?
1998.5 E1 SVT Contour #5482/6535
Page 2 of 4 1 2 3 4
Moderated by  mbb41_dup1
