Page 2 of 2 1 2
#47157 11/09/01 05:00 PM
Joe Offline
There was a dash piece under the steering wheelon my car and one of the bolts that holds it on was cross threaded on and I guess the assembly worker gave up half way. I got the johnson bar on it and reefed it tight and voila, no more rattle. I suggest tighening all you dash bolts
Joe, 98 GL sport (V6 MTX)
#47158 11/09/01 05:29 PM
O
O
my question is how do y'all know you have the same rattle? :rolleyes:
so i obtained a rattle in the dash after i installed my V1 radar detector. When i removed the A-pillar trim i ripped most of the back of it off. so it no longer fits tight. the bottom of it rattles against the dash. I just stuck a shim in there to fix it for now. i ordered another one. anyone know the proper way to remove/install these?
best of luck on your rattles. they are the worst (try an 80's VW laugh )
-eric
Please: put something meaningful in your post subject! NOT "please readme!".
"your" is possessive, "you're" is the conjunction that is short for "you are", "there" is for "the dictionary is over THERE", "their" is the possessive one, and "they're" is a conjunction that is short for "they are". have a nice day :rolleyes:
Silver Frost non-E1 SVT/Contour
see my registry/profile: http://contour.org/carprofile/carprofile.cgi?a=display&uid=00004623
#47159 11/10/01 02:04 PM
Originally posted by BlacknBlue:
I have had the problem for a while and it bothered me like crazy until I found that it was caused by the plastic piece where the defrost vents are - where the dash meets the windshield (I'm guessing this is only applicable to pre 99s).
Hadn't though of that. Got a '97.
Well, mine sounds like something is vibrating in the very center, almost dead center of the dash. Can't tell if it's an internal issue or a loose trim piece, but it's definatley right smack in the middle of the dash!! confused
James
jpett@flash.net
StolonTour97
Riding on 17" ADR Trauma's wrapped in Falken ZE512 215/40/ZR17
#47160 11/14/01 08:31 PM
I have an annoying buzzing rattle in the middle of the dash, a rappping-type rattle behind the instrument panel, and a high-pitched rattle at the bottom of the instrument panel. They all appear in the Fall and disappear in the Summer. I just turn the radio up! wink
#47161 11/15/01 01:59 AM
well, forget all that previoulsy mentions stuff. I looked into all that and still doesn't seem to help. i give up!! :rolleyes: Like Mysty said, I just turn up the radio now!! smile
James
jpett@flash.net
StolonTour97
Page 2 of 2 1 2
