well here my problem... i have a 95 gl with about 101,000 miles on it and have had the plug wires upgraded aling with intake and exaust...and now when i go up a hill at slow speed my car sorta surges n sumtimes it dies and when i start my car n let it sit the rpms fluctuate (sp) constantly i was reading somewhere else about the accel coil being bad,,, i know that accel is a company but what is the stock coil and where is it located and if thats the problem how much to get it replaced???? mad
95 gl I4, naxor R exaust, k&n intake, taylor wires,wings west touring wing, 98 se sideskirts, custom back bumper,catz fogz,2 15" jensen XS subs with mean machine amp
Stock Coil is pretty bomb proof. I've never heard of one going bad (I've heard of a lot of aftermarket ones dying though). HT leads often fail, coil is the block thing that your ignition leads go to (No thats the engine, its the smaller block thing at the other end laugh )
Rough idle is comman and can have a lot of causes. Normally vacuum realated
Underneath the coil is a rubber T piece, check this is intact as it often splits. Also the EGPD valve often plays up
If you give a more precise description of the idle problem, like at what revs, when hot or cold etc I'll have a go a guessing what its likely to be
Mad Mole
Visit Mad Moles Mondeo Madness
2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc.
192 BHP, Faster than a speeding Duratec!
the engine surges are only going up hill and the rpm changing is always when i start my car after sitting for a while...and i dunno if u have a atx but sometimes when i drive n let off the pedal my car sort of jerks as it shift back down gears..or i think thats what its doin
My coil pack went bad at about 88000 miles. I had it replaced. My car also jerks suddenly now when it shifts....bad sensor somewhere?
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
For what it's worth, my '97 Mystique started doing the fluctuating rpm's at cold startup (rollercoastering up and down)and over time began doing it in gear as well when I was stopped at a light. After some more time I finally got a CEL and found out I had a bad HEGO (heated oxygen sensor.) Replaced the sensor and no problem since.
'97 White Mystique 2.0 and
'98 Green Contour 2.5
F
F
What did the HEGO cost to replace? My '95 Contour does the same thing at idle and if you step on the throttle when it's in park it revs up to about (2200)?? , no tach, and just surges, won't rev any higher. Any suggestions?
Hego normally doesn't cuase the surging idle. That suggests a blocked Crankcase breather (PSV) valve to me. Its cheap to replace (just fiddly) and is supposed to be changed every 30k miles
Take a look at my web site I have a huge section on idle probs in my information pages
Mad Mole
