Posts: 834 |
i have a 95 se mtx and i did a a serach before asking i just wanted to know how many o2 senors do i have? and where are they located>?
HaHa You Watching me? Keep Watching
Posts: 32 |
The 95 V6 Duratec has two O2 sensors. They are in the manifolds, before the cat converters. Bank one is on the firewall side, and is more difficult to reach. Most people get to it from the underside. Bank two is up front, and it's in the manifold near the oil filter. Use an O2 socket to unscrew, it has a slot for the wires. If you replace, you can get OEM style (with connector attached), or replacement style, where you can cut off the connector half and splice it to the new wires. They are color coded. Replacement style has same sensor, but costs less. NAPA has them, also other auto stores. Bosch seems to be the preferred brand. Good Luck.
Posts: 731 |
Correction, I replaced my O2 sensor last weekend and there are what appear to be 3.  There are the ones mentioned above, and then there is another one, I don't have my car with me since it's in the shop, but if you look under the car you can see all three. One you can see by looking under the hood, and the other two you have to put the car up on ramps.
Austin -officially a troll
See it here
Pro-Flow w/ optimizer STILL for sale
Posts: 192 |
Mine has 4
Two under the car
Two on top ,one you can seein front
The othere I can not see [like yours?]
1999 GREEN Contour SE SPORT Duratec V6, ATX, SUNROOF, 93,000 Miles, P0420 ON&OFF -replaced DS O2 --did not FIX
*New TORQUE CONVERTER @ 53,000-Intermittent P1744
*New DASH at 53,000 and New DASH lifted-now using MOLLEY bolts to pull down
Posts: 834 |
ok now i know the difference between 95 nd 97 is 95 is obd1 and 97 is obd 2 right so... How right now? Alkaut you have a 95 right? i see that CONTOUR has a 97 see me must have obd2? so we only have o23 senors then
Posts: 1,977 |
Originally posted by COntour: Correction, I replaced my O2 sensor last weekend and there are what appear to be 3. There are the ones mentioned above, and then there is another one, I don't have my car with me since it's in the shop, but if you look under the car you can see all three. One you can see by looking under the hood, and the other two you have to put the car up on ramps.
You should have 4, your car is a '97 which uses OBDII, it has two before cat O2, and two aftercat O2. '95 has only two sensors, and both are before cat.
Posts: 9,602 |
Originally posted by AirKnight: You should have 4, your car is a '97 which uses OBDII, it has two before cat O2, and two aftercat O2. '95 has only two sensors, and both are before cat.
Exactly.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 731 |
Ok thanks for the correction.
See it here
I am Canuckian
I am Canuckian
Posts: 4,168 |
For clarification. All cars Contique equiped with OBDI have one O2 sensor per bank. All OBDII's have 2 O2's per bank. one upstream and one downstream. All upstream O2's for the record on the firewall side are a PITA to replace.
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
