well, after gutting my cats, making mil's, the car was good for about 400 miles, then the check engine light came on, i took out the mil's, replaced them with another set of mils, this time only good for 30 or so miles..then check engine light came on once again. I took my car to autozone and had the code from the PCM pulled and i got back the following errors:
PO135 (HEATER MALFUNCTION, 02 SENSOR, BANK 1 SENSOR 1)
PO141 (BANK 1 SENSOR 2)
PO 155 (BANK 2 SENSOR 1)
PO 161 (BANK 2 SENSOR 2)
I GUESS THAT MEANS THAT ALL MY 02 SENSORS ARE BAD, AND I DOUBT MY WARRANTY WOULD COVER IT B/C I WAS THE ONE WHO MESSED THEM UP
autozone quoted me $49.00 a piece for the two front ones (before the cat) and 89.99 for the ones located after the cat
does anyone know anythig more about these codes or have any input to help me
2000 Silver Cougar V6 MTX: kkm intake, dual exhaust, Razzi G/fx and High spoiler, taillight covers roush rims. 15.1@ 91mph
no CEL help... but oxygen sensors
The following is from the Ford TSP. In short, it doesn't seem that the O2s are bad, but rather something in common with all of them: the harness, battery voltage, or PCM:
P0135=Upstream Heated Oxygen Sensor Heater (HTR 11) circuit malfunction (Bank #1)
P0141=Downstream Heated Oxygen Sensor Heater (HTR 12) circuit malfunction (Bank #1)
P0155=Upstream Heated Oxygen Sensor Heater (HTR 21) circuit malfunction (Bank #2)
P0161=Downstream Heated Oxygen Sensor Heater (HTR 22) circuit malfunction (Bank #2)
Diagnostic Trouble Codes (DTCs) P0135, P0141, P0155 and P0161 indicate a short to ground, open, or short to VPWR in the HO2S heater circuit.
DTC/HO2S Reference List:
DTC P0135 = HO2S HTR-11
DTC P0141 = HO2S HTR-12
DTC P0155 = HO2S HTR-21
DTC P0161 = HO2S HTR-22
Possible causes:
-- Shorts to B+ in harness or HO2S.
-- Water in connectors.
-- Cut or pulled wires.
-- Disconnected wiring.
-- Open VPWR circuit.
-- Open GND circuit.
-- Low battery voltage.
-- Corrosion or poor mating terminals.
-- Damaged PCM.
* Visually inspect the HO2S circuit for exposed wiring, contamination, corrosion and proper assembly.
NOTE:
On some applications, a vehicle hoist may be required to access the HO2S harness.
