#469348 10/29/02 02:11 AM
clayre Offline OP
Well, neither the remote trunk opener or the floor lever will open the trunk any longer. What on earth could be causing this?? '98 Mercury Mystique LS
Jamie
1998 Mercury Mystique LS
#469349 10/29/02 02:13 AM
There is a switch behind the carpet panel near the bottom latch I believe. It's a safety feature in case you don't want your trunk opened without the key.
Mines right in front of the latch on the inside. it has a little orange cap on the lever.
www.ChicagoCEG.com 2006 White Grand Prix
#469350 10/29/02 02:35 AM
clayre Offline OP
Tried the lever in both positions. Was digging around in other parts of the forum, maybe a relay or solenoid. Boy I hate working on new cars. An really hate paying dealership prices.
Oh well, thanks though.
Jamie
#469351 10/29/02 02:35 AM
If that switch was tripped, the remote entry release would still work. Possibly the cable broke...?
#469352 10/29/02 02:55 AM
How bout if you have keyless entry and want trunk to pop with push of button? I heard there is a motor that needs to be boughten (its a factory motor) and thats all I need if thats it, anyone have any input for that?? Thanks
Alan 93 Acura Integra LS 5spd Horizon Gray Metallic ------------------------- -96 Gl Zetec ATX- Totaled as of 11/29/03 at 4pm Champagne Metallic CC Pics
#469353 10/29/02 03:26 AM
I recently had the same problem. I had the lock out on on the trunk and the remote started not working but just for the trunk, it worked for everything else. The interior light still came on when you pushed the button but no release on the trunk. They had to replace the solenoid and it is working fine now. Plus my key did not work so I was completely locked out of the trunk.
1998 BLK SVT CONTOUR #2980 of 6535 395,000(ish) km (and counting) SVTOA-TORONTO Chapter Director www.svtoa-toronto.ca
#469354 11/03/02 02:44 AM
Alan,
I just installed on in the wife's 98 to go with the aftermarket remote starter/keyless entry system.
I finally found the solenoid at the local u-wrench-it for 8 bucks and got it installed and working in about an hour. Installing it involved adding a relay and a wiring run from the remote module back to the wiring harness by the driver's side rear seat where I spliced into the factory harness. Mounting the solenoid is a tight fit. If you can find a Contour that already has it installed, remove the rear liner from the trunk so you can get an idea how it is put together. That helped me alot.
I have no idea what the solenoid and link would cost at the dealer, you'd have to go in and check.
Steve
#469355 11/07/02 10:16 AM
Where is the solenoid located? Is it in the fuse box in the engine bay? Thanks.
1998 SVT
#469356 11/07/02 02:52 PM
Open the trunk. Take off the plastic trim piece off the bottom of the trunk edge (the latch pops up through the piece I'm talking about). Find the solenoid and loosen the mounting screws just enough to move it. Move the solenoid away from the latch. Give it a test run to see if it works. If you have a fold down rear seat, you might want to fold it down prior to starting the adjustment. If it alls go wrong and the trunk doesn't open at all you can crawl in and readjust the solenoid's position. You might try adjusting the latch position also. I played with it for ~20 mins and it's ok now.
My interior release stopped working first then the remote stopped working, just like yours.
HTH .... Mark
Bless our servicemen & women overseas. L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
#469357 11/07/02 07:10 PM
I have a problem and question similar to whats being talked about here, I have the remote open, but it doesnt always work. I can hit the butten and I hear a click, but it doesnt unlatch the trunk. Is this silenoid related? The inside release always works.
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
