shows how ford is trying to rip people off some more,,, it's real easy. jack up one side, remove wheel, undo brackets, put new bar in (get some poly bushings), and your done,, you can put another jack under axle, behind brake where wheel was remove to get suspension even,,, easier to line up and get everything tight.... it's one of the easiest things you can do to a contour.
