CEG road warrior
CEG road warrior
Posts: 17,248 |
This topic is still going on?
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 2,091 |
Nah, It's done.
Posts: 2,291 |
Originally posted by Blackie: Nah, It's done.
Agreed...and I see your point; I guess I didn't come across the way I wanted to
Anonymous
Unregistered
Anonymous
Unregistered
oh yeah well well my ...... blah , i have a 98 tour v6 runs 15.2 all day long and its going bye bye cuz its too slow
Posts: 2,580 |
I've had both and I like the 6 better, but I'm not going to be divisive and go "Zetecs suc". Go to a Honda-child website for that. Isn't this the CEG and doesn't it include all CDW27 cars from ATX GL's to 3.0L converted SVT"s??? Anyway, I can understnd Big Joe's wanting to "climb another mountain", cool that he pushed his SE as far as he wanted to.
2005 Nissan Sentra 1.8 SE, Code Red. '00 Tropic Green Ford Escort SE [Contour's little cousin]
Posts: 21,653 |
Originally posted by CB99SVT: and don't care because I know whatever they do to mod there Ztec's I can do to my Duratec and will always have more power.
really?? please show me the 800-1000hp duratec? ooh wait there isn't one, i'm sorry. and you know how many turbo kits are out for the duratecs, hmm one, that can push it close to 300hp compared to one that will fit a contour that pushes 350hp and that others are available... but i guess that's not more power than your duratec.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,469 |
Originally posted by Kremithefrog: really?? please show me the 800-1000hp duratec? ooh wait there isn't one, i'm sorry. and you know how many turbo kits are out for the duratecs, hmm one, that can push it close to 300hp compared to one that will fit a contour that pushes 350hp and that others are available... but i guess that's not more power than your duratec.
Here you go.. http://www.fastcougar.com/forums/messageview.cfm?catid=63&threadid=56301That would be in excess of 1000 HP. The Dutweiller 450 HP turbo 2.5L is strongest street Duratec application I know of, though several 3L with turbo or S/C will soon challenge that. FWI..it really is no big trick to make HP with boost with even the smallest of motors. Boost also overcomes poor head design & lots of other deficiencies. Lots of marginal engines out there with turbos look like hot stuff. ANY motor has great potential with enough psi is what I'm saying..nothing to brag about.
1999 Amazon Green SVT Contour (#554/2760)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use."
-Soren Kierkegaard (as posted by Jato)
Posts: 61 |
My point was that if you take a Duratec and a Ztec and do the same mods the Duratec will make more power. You are correct that the current Ztec turbo makes more power but it does so with considerably more boost than the Duratec kits are using. If one was inclined to build a low compression Duratec and turn the boost up to 18 psi guess what it will make more power than a Ztec with the same mods and equal boost.
99 T-Red SVT #1634/2760
K&N filter
Aussie Intake Pipe
Pro-M 75mm & Optimizer
B&M Edge Shifter
Quaife LSD
Borla Cat back
MSDS Headers/sho-shop Y-Pipe
Dynoed at 184.2 HP & 157.2 TQ
14.53@94.15
Posts: 3,465 |
Originally posted by CB99SVT: My point was that if you take a Duratec and a Ztec and do the same mods the Duratec will make more power. You are correct that the current Ztec turbo makes more power but it does so with considerably more boost than the Duratec kits are using. If one was inclined to build a low compression Duratec and turn the boost up to 18 psi guess what it will make more power than a Ztec with the same mods and equal boost.
well I just got cam gears can you show me who makes cam gears for the Duratec??? OOH wait a minute they don't make any for the duratec...  I could go on with after market parts we have avaliable that you duratec owners do not have if you would like...
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 21,653 |
Originally posted by Dan Nixon: Here you go.. http://www.fastcougar.com/forums/messageview.cfm?catid=63&threadid=56301 That would be in excess of 1000 HP. The Dutweiller 450 HP turbo 2.5L is strongest street Duratec application I know of, though several 3L with turbo or S/C will soon challenge that.
let's see, that link is for a 3L duratec,, hmm which you don't have (i have my zetec  ), it has two turbos (zetecs only need one for 1000hp), and it's RWD. like zetecracing said, more parts available for zetec = more power available. and don't forget a zetec can be bored for some more displacement, and it's lighter. and the water pump doesn't fail.
98.5 SVT
