Posts: 13 |
rmcd79,
Check the seal just above the large red reflector. If there's any separation between the gasket & plastic - that's most likely the culprit. I sealed mine with clear silicone sealant from the outside. Noticeable when looking closely, but did the job. You can also take apart the assembly and replace the gasket for a cleaner fix (i had trouble removing rusted screws)
Posts: 277 |
There is a much easier way to fix the same problem. I had a leaking vent on the passanger side as well and fixed it with a bit of aresol type silicone sealant purchased from Home Depot. I think it was $3 something a bottle. Haven't had a problem since. You may want to give it a try.
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound Administrator www.fordcontour.org
Posts: 1,251 |
Again, the search engine prevails! Another fix I've been looking for.
Posts: 918 |
FWIW, I am still battling this problem. I checked the taillight, the vent(which used to leak, but I fixed), and around the non power antenna trim on the outside of the car(again, fixed it). I am getting frustrated, but I haven't had much time to play with it. I have to get it fixed before I build a new box and floor.
************************* 2000 SE Sport V6 Deep Navy CC Metallic My 2G Sport *************************
Posts: 105 |
My wifes 99 rear window seal wasn't set in right at the factory and her trunk leaked when it rained out. The dealer put a new window gasket and now the problem is fixed.
Green 2000 SVT #1166 mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened http://www.geocities.com/savinoss/Cars.html other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
Posts: 956 |
** CT - USA **
* 96 Contour Gl 2.0 5 Speed Manual / Clarion CD Change 8" Subwoofer & Sony Amp (LOUD !!) The Cleanest !!!
* 92 Mazda Protege 5 Speed Manual / 1.8
* 94 Yamaha Virago 535 (better than Viagra !!)
Posts: 1,847 |
Originally posted by rmcd79: ok I have a leak in my Mystique but it's not from the vent thing, mine is actually running in through the back up lights in the trunk. Anyone else have this problem and maybe an easy fix? My trunk leak had nothing to do with the vents. Water was entering the trunk by actually going under the weatherstripping between the trunk and the trunk lid (that big black peice that goes all the way around the opening). The weatherstripping attaches to a metal lip that runs the entire circumference of the opening. At two points (driver and passenger side), that lip runs near vertically for a bit. That is where the water was going under the weatherstripping, up and over the lip and into the trunk. I took the weatherstripping off, applied a liberal amount of caulk to the entire lip, and the leak was fixed. You clould see the water entering the trunk if you folded down the rear seats, climbed into the trunk, and had someone spray the closed trunk from the outside. The spare tire well was filled with water several times after a rain before I sealed the weatherstripping. I've never had a leak since.
95 Contour SE ATX V6 "Cracked" Secondaries DMD Installed SVT Brakes
Posts: 918 |
Originally posted by svtavino: My wifes 99 rear window seal wasn't set in right at the factory and her trunk leaked when it rained out. The dealer put a new window gasket and now the problem is fixed. OMG, I just found out tonight I have the same problem! I took out my box and climbed in with a flashlight. I had previously been concentrating on the "grill" and antenna area since they had given me trouble before. I had my brother spray the car, and I saw a whole **** load of water pouring in where the trunk lid "arm" thing has space to open(best way I could describe it..lol). Anyways, my wife works for Safelite auto glass and I can get it fixed for almost nothing tomorrow as opposed to waiting for the dealer to get an auto glass place to come and do the same thing for my $50 ESP deductible and 3 days w/o a car. Thanks for mentioning it! Now I can fix it and get my new box and floor built.
Posts: 62 |
When I bought my car, I found 4 different leaks in the trunk. Three of them were easy to fix, However, one of them is way up behine the left rear quarter panel where is is really hard to see. So far I have use a whole tube of silicon sealant and still have not the leak stopped. It only leaks when driving in the rain from the wheels throwing the water up into the wheel well.
96 Black SE 2.5L V6 ATX
