#46793 10/29/01 03:00 PM
PAA Offline OP
One of the damn things came out on my way home from work Friday. I was on the highway and heard something hitting under my car, come to find out a few miles down the road it was the bolt on the top passenger side caliper. It took those few miles to get some shaking and vibration and when I pulled off the road my caliper was sitting against the rim. I have a $1.50 Home Depot bolt in right now and I finally found a dealer that had a bolt in stock.
Has anyone ever had any problem with the bolts backing out any? I check all of them this weekend on the front and they were a little loose. If so, any solutions?
'98 SE Sport
Fog light mod and sidemarkers
No significant power mod
#46794 10/29/01 06:26 PM
Nope - I've only had problems with the caliper bolts not coming off! smile
Like this weekend when I was trying to replace the right rear rotor. The bottom caliper Torx head stripped after applying over 200 lbs. ft. of torque and it still didn't budge. Ended up cutting the bolt head off, buying a new regular hex head SAE bolt and re-tapping it. Another simple job made difficult by Ford Motor Company. Why, oh why did the brilliant engineers decide it was a great idea to use a Torx head bolt for the rear calipers? :rolleyes: Does that make sense to ANYONE? mad
'96 Contour SE, black / opal grey, MTX, every option, KKM intake, resonator removed, Flowmaster Series 40 DeltaFlow, GoodYear Eagle HP's, 115k miles, new paint 7/01. Driven cross-country 4 times.
'70 Corvette Stingray Coupe, Cortez Silver, 454 bored to 462, Muncie M21, too many mods to list, lots of fun. 335 rwhp / 365 rwtq
'02 Corvette Z06, Electron Blue / Black, every option. Stock for now...
#46795 10/30/01 10:41 PM
Makes about as much sense as buying the new Mitsubishi Lancer. There's no point! Its not real!!!
Ryan M. Taylor
1996 GL V6 ATX Desert Violet
{__ 15" 98SE 12-spoke wheels, 205/60-15 Pirelli HP Unidirectional Tires __ KKM TrueRev Intake __ Bosch +4's __ Pioneer DEHP4000 __ 9mm Ford Motorsport Wires __ 2.25" Dual Exhaust, Catco Cat, Flowmaster 40 Series, no res __ Mobil 1 5w30 badge mod __ Pilot Millenium Series H.I.D. 55W Fogs __ Xenon 100W Highs __ Intermittent Ford P0420 CEL Option __}
http://rmtaylor.webhop.org
AIM: Vinnland990
