Page 2 of 2 1 2
#467755 10/29/02 04:12 AM
ALWAYS, ALWAYS, ALWAYS, ALWAYS check the gap and correct it if needed on fresh spark plugs.
NEVER, NEVER, NEVER, NEVER install new plugs without checking the gap and adjusting it if needed.
The emissions decall on the hood should have the spark plug gap. IIRC it is .052" to .056". My personal preference is to set it at the side end of the spec.
#467756 10/29/02 08:37 AM
Originally posted by NorMich99SE:
I seem to remember reading or hearing somewhere that you shouldn't gap platinum plugs..something about it scraping off the platinum coating or something
Buy a feeler gauge set. A proper feeler gauge set will have a tool to bend the ground electrode & be much more accurate. DO NOT use the cheap POS gapper disc's.
#467757 10/31/02 03:36 AM
At 0.70 on the front bank do you think my CEL having a low CAT efficiency on rear bank makes sense ?
1999 GREEN Contour SE SPORT Duratec V6, ATX, SUNROOF, 93,000 Miles, P0420 ON&OFF -replaced DS O2 --did not FIX *New TORQUE CONVERTER @ 53,000-Intermittent P1744 *New DASH at 53,000 and New DASH lifted-now using MOLLEY bolts to pull down
#467758 11/02/02 12:32 AM
2
Well, couldn't get the AWSF's so I got the autolite DP's, same thing,and gapped to .50. Big difference. Thanks Demon.
98 EO #587 Currently Dirt Jumping
Page 2 of 2 1 2
