Posts: 190 |
HI THERE
PEOPLE ARE TELLING ME I SHOULD CHANGE MY WATER PUMP BECAUSE I HAVEN'T DONE SO SINCE THE CAR WAS BORN. NOW I AM AT 150,000KM.
WHAT IS A WATER PUMP? HOW DO I KNOW IT IS NOT WORKING? DO I NEED IT REPLACED WITH A "METAL IMPELLAR"?
1999 Ford Contour SE (Black)
S&B Powerstack Air Filter
Brullen Cat-Back Exhaust System (Loud Setup)
Sylvania SilverStar Headlight Bulbs
MSN Messenger: ddasilva99@hotmail.com
Posts: 644 |
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 263 |
I believe that your year has the white impeller, which is improved over the old impeller which is black.
I do not blelieve that there are any issues with the white impeller.
1996SE sports package, Duratec MTX No mods yet.
80K Kilometers.
Wife has 1996GL Zetec ATX.
Posts: 427 |
Originally posted by jborge: I believe that your year has the white impeller, which is improved over the old impeller which is black.
A couple of weeks ago, I didn't even have an impeller.. I had lotsa black dust and debris though.. Now I have a metal impeller, a large bill, and no headaches!
Kyo
1997 Mystique GS Duratec ATX -- sold
2005 Focus ST - Quicker! - Still a Duratec!
Posts: 1,603 |
My 98.5 had a White Impellar. When I replaced it at 60,000 miles, it had two vanes cracked. Such an improvement ???
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 2,408 |
Back in the cast-iron age a bad water pump didn't matter as much. All the new aluminum engines warp heads, spin bearings, or just die if they overheat. Water pumps are a lot cheaper than engines. Mine was about 50$, one hour, and one scraped nuckle.
Posts: 4,693 |
It would probably be safer to say the the water pumps with white impellers have less issues. I don't think it is correct to say that the white impeller completely ended the problems of the impeller falling apart.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 16 |
You asked how to tell if it's not working. You only have moments to see the temp gauge rising very fast, before your engine is seriously damaged. If the impeller is cracked and near self-destruction, there will be no external sign of it whatsoever. That's why people are replacing them proactively. Mine had some very small cracks at about 53,000 miles. Were you just kidding about what a water pump is? It moves water from the engine, where it's heated, through the radiator, where it's cooled, and back to the engine. One of the things you can not go without except for a very short time.
'98 SE V-6 5-spd ASB Silver stock
89K miles in May '05
Like it for Oregon coast canyons!
Posts: 237 |
How many miles when yours broke? I have a 97 Mystique w/90k on it now. Thinking Timing belt at the same time.
'97 Mercury Mystique GS (Not mine anymore...)
Now running a Toyota Matrix XR
Red, 16" wheels, Sunroof, VVT-i
Posts: 9,442 |
Originally posted by zaphod_fl: How many miles when yours broke? I have a 97 Mystique w/90k on it now. Thinking Timing belt at the same time.
If your going to do the timing belt then do it, but FYI the water pump failure are common in the Duratech's not so much the Zetecs
