grinder Offline OP
Here is what dealer recommends:
1) EEC Diagnosis
2) Mass Air Flow Sensor and Major Tune - $ 160 exchange part
3) Air induction Service - 99.95
4) Electronic Trans Diagnosis
Replace Vehicle Speed Sensor - 59.00
Replace Turbine Shaft Sensor - 29.00 (Not In Stock)
Tranny Flush - 99.95
5) Diagnose Temp Guage problem
Replace Temp Sender - 49.00 (Not In Stock)
6) Coolant Flush - 89.95
Total Cost, including 5 hours of labor is 1286.00 + tax.
Parts cost = 586.85
Labor cost = 139.83 per hour
Sounds pretty exhorbitant to me, but I know next to nothing about cars .
What do you guys think?
I got a bridge in New York that's for sale if your interested
grinder Offline OP
That's kind of what I thought. Thanks.
By the way...it's not the Brooklyn bridge, is it??
In reply to:
Tell me you went across the border and that's Canadian $$... Even then.... WTF??????
95 Contour SE ATX V6- SOLD 2001.5 VW Passat GLX V6 Tiptronic 2004 Honda VTX 1800N1 There are no stupid questions. There are a LOT of inquisitive idiots.
grinder Offline OP
Originally posted by Sandman333:
In reply to:
Well to be honest...that might be a little bit unfair. 1286 - 586 = 700 for 5 hours of labor. Works out to 140 an hour.
Of course that prolly includes things like tranny fluid and coolant. At least I hope it does. Doesn't matter...I am taking it to another shop for another estimate.
Bring your car to North Dakota and have it fixed, labor is around 60$ an hour, that 139$ is insane but i spose its because of higher pay rate in bigger cities
Alan 93 Acura Integra LS 5spd Horizon Gray Metallic ------------------------- -96 Gl Zetec ATX- Totaled as of 11/29/03 at 4pm Champagne Metallic CC Pics
In reply to:
the going rate is $65-80CND/hr around here. $140US that more than 200CND, and i was complaining when i got charged $50/hr when i rebuilt the tranny.
95 SE MTX DH UIM, 65mm TB, SC CAI, Quaife, Centerforce, Fidanza, UR Pulley, F/R Strut Braces, Cross Drilled Rotors, S.S. Brake Hoses, 18" Enkei RS5, SVT Engine Mounts+Inserts, MSDS & y-pipe, Trubendz resonated exhaust & MagnaFlow cat
You must have seen my sale on eBay
